![]() | Home > Puma (Tdci) > Another rattly Puma post |
From experience, yes there definitely is a world of difference between supermarket Diesel and Premium Diesel. I have run the first years continuously on (French) supermarket diesel, and the engine was quite noisy, as well as the EGR valve cleaning cycle after switching off. I did not know better than that was normal then....
I had followed a thread on Def2.net here about those in favor of BP Ultimate, and those who call the fact that there would be a difference fairy tales. I initially was on the fairy tales side..... Until I tried BP Ultimate now more than a year ago. Indeed a world of difference, immediately the engine sound became less clatter, much milder, and quickly the EGR cleaning cycle became a much gentler chukka chukka chukka... I never looked back, and as I cannot find any BP stations in France anywhere close to the border, I now use nothing else anymore than our local Swiss BP Ultimate. I pay the premium, maybe there even is a mpg improvement, although have not measured that. One more thing which is not bad, but I don't know if it applies to all EU countries, here in Switzerland BP Ultimate diesel is 100% mineral diesel, so no bio-diesel at all. Definitely a pro too. Also take a look at the below thread which is specifically on this topic. http://www.defender2.net/forum/topic11415....p+ultimate You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
1ten.neuss Member Since: 07 Nov 2008 Location: Neuss Posts: 27 ![]() ![]() ![]() |
Even more expensive on a Puma with aircon is the fact, that the lifting eye hammers on an a aircon tube in case one out of two screews is missing (as in my case). I simply removed it completely before an expensive tube replacement to be happen. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
rossy,
not sure if this will be any help to you but I had (still have to a much smaller extent a similar sound), since new the following has been done replaced g'box replace t'box input shaft run on 2so have injector learn carried out adjusted hand brake cleaned maf and map sensors tightend loose heat shield and heat shield support off manifold my gut feeling is there are issues with the egr (contrary to what has been suggested) so I'm looking to replace this. engine runs really well compared to how things have been and I'm a great fan of the 2so using 1/3 ltr each fill up. hope you get to the bottom of it. |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
The stealer recently took most of the slack out of the driveline on my 2010 Puma and it's much more pleasant to drive but I still have that bloody awful rattle at certain throttle openings and it's worse when the thing is hot.
I also have a BAS Remap and was hoping this would help but it hasn't. What is the "injector learn" and how does it get done? AlanH. |
rossy,
not sure if you've got to the bottom of it yet but jus another thought. are you happy that the hand brake is correctly adjusted? |
Just a thought but have you checked the security of the turbo and crankshaft position sensor heat shields? Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
Thanks Caterham handbrake's fine and the other things you mentioned. I had a relearn but it was the first time my dealer has done one of those on a Defender so I don't know if they did it properly. I very much doubt its the EGR as its very quiet in self clean mode. Its a bit oily at the base of one of the injectors but it hasn't got any worse so I don't know if thats got anything to do with anything |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4742 ![]() ![]() |
Just a thought. Like me you are adding 2SO to JASO FB spec. Have you tried adding 2SO to the higher FC spec? 1982 88" 2.25 diesel
No I haven't checked them yet Steve but will do soon and after that I'll annoy the stealer again. Is this "injector learn" a mechanical adjustment or fiddling wiht the computer like with a remap?
Please advise. AlanH. |
alanh,
injector learn is via the ecu like a remap - my understanding is that its a learn process to fine tune the injectors so they fire precisely when they should. for me I think it made the engine sound just a little crisper I hope you get sorted. I sure so are going to think I sound like an old record but I'm a little sensitive about my LR having endured years of problems.... anyhow not knowing how much you know about LR I would strongly recommend lossening off the hand brake adjuster by 1/2 to 1 turn and giving that a try just to see if it has any impact. if you know where the adjuster is its a fews seconds to do and a few seconds to put back where it was. ps - I take no responsibility for the above and won't accept any claims should your truck implode, fall to pieces or start a civil war or anything else for that matter ![]() good luck. |
So it's really something which needs to be done by a mechanic with the vehicle and a computer plugged in rather than by a remotely tuned remap as with BAS?
Sounds like another trip to the stealer. Cheers. Alan. |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 810 ![]() ![]() |
Can not be done remotely.... And ideally I'd want it done by a main dealer using SDD. The correct process is pump learn and then pilot correction. The engine needs to at working temperature... I.e. nice and hot. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Thanks Ian, now I'll be able to tell the stealer how it's done!
![]() Cheers. Alan. |
Would'nt be something loose and rattling around inside your head by any chance? Better get the Mrs. to look in your ears.
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
