Home > Puma (Tdci) > Idling surges |
Landyrover Member Since: 04 Jul 2011 Location: Northampton Posts: 33 |
Could this be an injector problem?? "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson)
4th Sep 2011 1:42pm |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 |
Mine only does it cold, starts ok and idles but when rpm run between 800 and 1200 feels almost like half a cyl missing. Also smoke. When it warms all good. Cold here at the moment (mid winter) 8 dec cel. In on Thursday to find out why. Will post if they fix It.
Allan |
5th Sep 2011 3:10pm |
jasonshum Member Since: 10 Jun 2011 Location: Hong Kong Posts: 13 |
this..??
5th Sep 2011 5:52pm |
EGR related also......
Try to disconect the EGR connector Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
5th Sep 2011 6:06pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2432 |
^^^^^^^^ Most problably. My EGR was properly shut down and no more idle issues. Puma 110" SW
5th Sep 2011 7:00pm |
Mine does the miss like thing only when cold and when throttle used very lighyly at very low rpm. EGR was replaced last month, not that that means anything.
Allan |
5th Sep 2011 11:16pm |
Where is this please? Cheers "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) |
6th Sep 2011 6:27pm |
That's it, but settled after 10-15 seconds. Did you fix this? "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) |
6th Sep 2011 6:29pm |
rev it Member Since: 25 Jul 2011 Location: Kent Posts: 6 |
Hello, About two weeks ago, I had the fuel metering valve fitted. So far I have had no odd surging (fingers crossed) since.
6th Sep 2011 8:08pm |
Good news! "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson)
6th Sep 2011 9:15pm |
Took mine in today to sort. Will report when they return it. I also have a caster issue, slight pull left that i want fixed, doesn't annoy around the city but on long trips its a pain.
Allan |
7th Sep 2011 1:48pm |
Not Yan~~Too Bad~~~ |
7th Sep 2011 5:01pm |
fuel metering valve fitted?Change This is ok..?h |
7th Sep 2011 5:22pm |
Garage diagnosed sticking EGR valve. No fault codes generated but they say noise made when it goes through the self-cleaning routine when the engine is turned off is excessive.
Nick "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) |
8th Sep 2011 7:06pm |
