Home > Puma (Tdci) > Idling surges
Page 2 of 3 <123>
Landyrover
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Could this be an injector problem?? "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson)
Post #87588 4th Sep 2011 1:42pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Mine started idling a bit wonky this afternoon. It'd jolt ever so slightly and make a sort of clunk noise, then it'd sound quite tappety and as though it was knocking ever so slightly. Rev it a tiny bit and it'd go back to normal for a few seconds and then do it again. Oil level correct, etc.
Also seemed to chuck out a fair amount of blue smoke this morning under acceleration when cold... not sure if thats related somehow....
Post #87745 5th Sep 2011 1:08pm
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Mine only does it cold, starts ok and idles but when rpm run between 800 and 1200 feels almost like half a cyl missing. Also smoke. When it warms all good. Cold here at the moment (mid winter) 8 dec cel. In on Thursday to find out why. Will post if they fix It.
Allan
Post #87761 5th Sep 2011 3:10pm
jasonshum
Hong Kong
this..??
Post #87782 5th Sep 2011 5:52pm
dgardel
Italy
EGR related also......
Try to disconect the EGR connector Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #87788 5th Sep 2011 6:06pm
MK
^^^^^^^^ Most problably. My EGR was properly shut down and no more idle issues. Puma 110" SW
Post #87803 5th Sep 2011 7:00pm
Allan
Mine does the miss like thing only when cold and when throttle used very lighyly at very low rpm. EGR was replaced last month, not that that means anything.
Allan
Post #87837 5th Sep 2011 11:16pm
Landyrover
Where is this please? Cheers "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson)
Post #87932 6th Sep 2011 6:27pm
Landyrover
jasonshum wrote:
this..??
That's it, but settled after 10-15 seconds. Did you fix this? "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson)
Post #87934 6th Sep 2011 6:29pm
rev it
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Cairns Blue
Hello, About two weeks ago, I had the fuel metering valve fitted. So far I have had no odd surging (fingers crossed) since.
Post #87949 6th Sep 2011 8:08pm
Landyrover
Good news! Smile "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson)
Post #87969 6th Sep 2011 9:15pm
Allan
Took mine in today to sort. Will report when they return it. I also have a caster issue, slight pull left that i want fixed, doesn't annoy around the city but on long trips its a pain.
Allan
Post #88049 7th Sep 2011 1:48pm
jasonshum
Hong Kong
Landyrover wrote:
jasonshum wrote:
this..??
Not Yan~~Too Bad~~~
Post #88080 7th Sep 2011 5:01pm
jasonshum
Hong Kong
fuel metering valve fitted?Change This is ok..?h
Post #88086 7th Sep 2011 5:22pm
Landyrover
Garage diagnosed sticking EGR valve. No fault codes generated but they say noise made when it goes through the self-cleaning routine when the engine is turned off is excessive.
Nick "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson)
Post #88275 8th Sep 2011 7:06pm
Page 2 of 3 <123>
