![]() | Home > Off Topic > What’s the stickiest strongest contact adhesive. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20717 ![]() ![]() |
Some of them aren’t good at all as you say.
Just this week I’ve used this one: https://www.ebay.co.uk/itm/Trim-Fix-500ml-...890.l49292 I haven’t had a problem at all with it, best one I’ve used. It is indeed a spray type though, but it work well is all I can say. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
One of my chums who does trimming uses this, it’s pretty aggressive in his own words.
https://www.ebay.co.uk/itm/122242645508 |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
I’ve used the 528, super strong quick use contact adhesive, but you’ll need to use in a ventilated area. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3354 ![]() ![]() ![]() |
Day old Weetabix. You need a kango drill to get it off a bowl. WARNING.
This post may contain sarcasm. |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1314 ![]() ![]() ![]() |
I need to stick some 3mm rubber mat to plywood (making a platform to groom the dog on)
Thinking of using Evo Stick Impact adhesive - anyone used that? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4255 ![]() ![]() ![]() |
Thanks all, I’m going to try the Evo Stick 528. It has numbers instead of a name so logically must pro-grade not for the DIYers.
Zen- I said I wanted to glue it down, not fuse it at the molecular level! ![]() |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
Gorillas wicked stuff, it also won't harm the underside of plastic, there's the water type and the caulk type.
Caulk type is fantastic but it really does take a while to bond I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Plywood is quite absorbent - you may get better results if you prime it first. Darren
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5854 ![]() ![]() |
Be very careful of using the contact adhesive with rubber mat. It makes the rubber deform with the chemicals, and it doesn’t return to shape.
I’ve had good results with spray adhesive but ply needs to be sprayed with glue as well as covering material, and ideally primed beforehand. I just used watered down unibond/PVA |
Darcy Fairfax Member Since: 06 Oct 2014 Location: London Posts: 721 ![]() ![]() ![]() |
You’re not wrong mate |
Evo Bostik must be good, all the 70's Punks couldn't have been wrong!!
Though they didn't 'stick' around for long!! (RIP my punk school chum, known as Evo) ...true story. |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1051 ![]() ![]() ![]() |
I used Glover bond for sticking carpet to plastic. Sets very quickly and has held up well so far. Not sure if you'd need to prime the plywood first though.
