Home > Tdi > Injector leak?
Jeebs
United Kingdom 1995 Defender 90 300 Tdi HT Barolo Black
Injector leak?
I’ve been checking over the 90 as chances are I’ll be using it to get to work on NYD, as I don’t fancy killing my self in a rwd 360bhp BMW in this weather.
While checking in the engine bay, I noticed whilst running there is a steady drip of diesel from the circled area on injectors 1 and 2. I’ve not noticed this before and half wonder if it’s due to the cold and everything having contracted and bit.
It’s a 207k 16L 300tdi.
Is it the fuel return pipes that have just got old and worn or are the injectors shot?
Post #875238 30th Dec 2020 4:49pm
dorsetsmith
MJN100910
Pipe-spill return fuel injection
ERR1304
Washer-sealing, Engine Code 11L 2.5 TDi Diesel Turbo Manual QTY8
300Tdi
fuel return pipes do split and leak and banjo copper washer too if High presser metal fuel pipe make shore they nipped up 1/4 turn but do not overtighten banjo bolts
(Red ) but do not overtighten banjo bolts
(Orange ) High presser metal fuel pipe
Post #875245 30th Dec 2020 5:03pm
Jeebs
Thanks Dorset.
Is it 4 of the washers? One per cylinder?
Post #875247 30th Dec 2020 5:08pm
Retroanaconda
Eight of the washers, they’re banjo bolts so one each side of the fitting for each injector. The hose looks perished so it might be the source of the leak also.
Don’t overtighten the leak-off banjo bolts - they snap very easily.
Post #875253 30th Dec 2020 5:14pm
Rednaxela
If the braided/rubber pipes are perished the engine should start better (after sitting/overnight etc) with new ones.
Post #875282 30th Dec 2020 6:46pm
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I changed my braided pipes with some I got from Halfords for about £5. Takes about 3 minutes and the old ones were very brittle.
Post #875342 30th Dec 2020 9:56pm
Jeebs
Bits and bobs ordered, just at the mercy of Bearmach and their Christmas hours.
Can’t for love nor money find banjo bolts, sold out everywhere seemingly. I’ll just have to be careful. Case of nipping them up then a 1/4 turn?
Post #875347 30th Dec 2020 10:07pm
Mo Murphy
Run the bolts down to stop and then maybe 10°.
50 Shades of Pennine Grey
Post #875364 30th Dec 2020 11:08pm
Oldowner
In twenty plus years of 300tdi ownership The only leak off hose I have found that actually lasts is St Gobain Tygon hose. Expensive but worth it.
Every braided hose I have tried has lasted 6 -9 months before breaking down.
Post #875380 31st Dec 2020 5:53am
Jeebs
Fixed today. Only one snapped banjo on cyl 4.
Overtightened it going back on and snapped it. Luckily had the old ones so no issues.
Post #876943 7th Jan 2021 9:14pm
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
300tdi fuel return hose
Does anyone know the internal and external diameter of the flexible braided hose needed for the fuel return hose?
Post #1015907 21st Nov 2023 1:10pm
