Home > Puma (Tdci) > CAR PLAY Help !!!!!!
bunnyman
England 2009 Defender 90 Puma 2.4 HT Galway Green
HI all can anyone recommend a good car radio unit with car play for my Tdci defender
Regards Bunny
Post #874700 26th Dec 2020 1:12pm
1 or 2 DIN? $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #874705 26th Dec 2020 1:33pm
bunnyman
Hi sorry do not know what the difference is ?
Post #874708 26th Dec 2020 2:29pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
This unit might suit you, have a read here:
https://www.defender2.net/forum/topic54638.html
Post #874711 26th Dec 2020 2:58pm
bunnyman
Thank you Daz
Post #874715 26th Dec 2020 3:29pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
If you go for the double din then also consider the depth of the unit as some need parts being moved/massaged behind the dash that you donโ€™t see like heater ducts etc.
The single din have to open out so block the hazzard switch when open, something that I donโ€™t like, hence I am in the process of selecting a double din unit. Though which one yet I donโ€™t know, tempted by the alpine 702D but itโ€™s quite an old unit so man thinking is there will be a new version as soon as I buy one. So I have the conversion kit but at present no actual radio.
Pioneer are also put in a lot but quite $$$ then you have JVC and kenwood that are basically the same, but they also have slim units that fit easilly. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #874743 26th Dec 2020 7:51pm
bunnyman
Thank you is there much difference in price for either a single or double all I and fitted
Post #874751 26th Dec 2020 9:21pm
Race.it
The main expense from what I can see is the double din facia, they ca be about ยฃ200.
So you need to factor that onto the price of the double din.
If you google double din facia for defender you will see different ones depending if you have a tdci or a earlier dash Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #874752 26th Dec 2020 9:26pm
1 & 2 DIN are single or double.
2 Din requires dash cutting. 1 DIN doesnโ€™t personal choice really.
I have a 1 DIN Pioneer AVH 7200DAB.
It does everything I could possibly want.
Thumbs Up $W33T $0U7H3RN $UG4R
Post #874760 26th Dec 2020 10:45pm
Post #874761 26th Dec 2020 10:46pm
paulas
I have the pioneer aswell, no problems with it. Would recommend it
Post #874779 27th Dec 2020 11:51am
bunnyman
Does the pioneer unit work ok with mobile calls
Post #874798 27th Dec 2020 2:08pm
Mine does, can't really fault any aspect of it. Thumbs Up
Post #874799 27th Dec 2020 2:20pm
It does indeed, itโ€™s a really popular model as you can see which is why I joined forces and got one too. Thumbs Up
**Edited** To correct silly spell check typing error. Rolling Eyes $W33T $0U7H3RN $UG4R
Post #874800 27th Dec 2020 2:34pm
DAZ110
Just a bit of a squeeze getting all the wires down behind the dash.
Post #874804 27th Dec 2020 3:49pm
