Home > Puma (Tdci) > CAR PLAY Help !!!!!! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20355 |
1 or 2 DIN? $W33T $0U7H3RN $UG4R
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
26th Dec 2020 1:33pm |
bunnyman Member Since: 29 May 2013 Location: herts Posts: 123 |
Hi sorry do not know what the difference is ?
26th Dec 2020 2:29pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2038 |
This unit might suit you, have a read here:
https://www.defender2.net/forum/topic54638.html |
26th Dec 2020 2:58pm |
Thank you Daz
26th Dec 2020 3:29pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 817 |
If you go for the double din then also consider the depth of the unit as some need parts being moved/massaged behind the dash that you donโt see like heater ducts etc.
The single din have to open out so block the hazzard switch when open, something that I donโt like, hence I am in the process of selecting a double din unit. Though which one yet I donโt know, tempted by the alpine 702D but itโs quite an old unit so man thinking is there will be a new version as soon as I buy one. So I have the conversion kit but at present no actual radio. Pioneer are also put in a lot but quite $$$ then you have JVC and kenwood that are basically the same, but they also have slim units that fit easilly. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
26th Dec 2020 7:51pm |
Thank you is there much difference in price for either a single or double all I and fitted
26th Dec 2020 9:21pm |
The main expense from what I can see is the double din facia, they ca be about ยฃ200.
So you need to factor that onto the price of the double din. If you google double din facia for defender you will see different ones depending if you have a tdci or a earlier dash Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
26th Dec 2020 9:26pm |
1 & 2 DIN are single or double.
2 Din requires dash cutting. 1 DIN doesnโt personal choice really. I have a 1 DIN Pioneer AVH 7200DAB. It does everything I could possibly want. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
26th Dec 2020 10:45pm |
26th Dec 2020 10:46pm |
paulas Member Since: 23 Nov 2018 Location: cheshire Posts: 23 |
I have the pioneer aswell, no problems with it. Would recommend it
27th Dec 2020 11:51am |
Does the pioneer unit work ok with mobile calls
27th Dec 2020 2:08pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17373 |
Mine does, can't really fault any aspect of it.
27th Dec 2020 2:20pm |
It does indeed, itโs a really popular model as you can see which is why I joined forces and got one too.
**Edited** To correct silly spell check typing error. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช Last edited by custom90 on 27th Dec 2020 6:48pm. Edited 1 time in total |
27th Dec 2020 2:34pm |
Just a bit of a squeeze getting all the wires down behind the dash.
27th Dec 2020 3:49pm |
