Home > Td5 > No glow plug relay |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6627 |
70A relay needed 1988 90 Td5 NAS soft top
2015 D90 XS SW |
22nd Dec 2020 11:59am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 |
Worth trying a relay in there. Think the part number is YWB500220
Not certain whether the same on a TD5 but for TDCi also check fuse 38. Does make you wonder who removed it though and more importantly why? > 110 XS Double Cab |
22nd Dec 2020 8:05pm |
souster4 Member Since: 11 May 2014 Location: West midlands Posts: 153 |
Thanks chaps will give it a go and see what happens.
I've still had the glow plug light ignite on the dash though? |
24th Dec 2020 11:05am |
Glow lamp control and glow relay control are separate ECU functions. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
24th Dec 2020 11:07am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5767 |
I would test with a meter first, before just poking a relay in.
24th Dec 2020 1:32pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2263 |
How did you test them without a relay ?
24th Dec 2020 2:53pm |
Check you’ve got 12V to relay carrier, check the resistance on the wire out to the blow plugs isn’t a short direct to earth. Check that the glows plugs aren’t already getting 12v from some other source or you've miss diagnosed the relay carrier.
You could disconnect the wire to the glow plugs and put a test bulb into the system instead. |
24th Dec 2020 3:23pm |
Thanks very much chaps. Hope you had a good Christmas.
I tested the glow plugs with jump leads on the bench, they are perfect. I'll do some multimeter testing I think, instead of just chucking a relay in. Tis strange no relay I think |
26th Dec 2020 9:43pm |
I'll be interested to hear your findings > 110 XS Double Cab
6th Jan 2021 10:38am |
