Home > Td5 > No glow plug relay
souster4
No glow plug relay
Hi guys
I've been wiring in an additional fusebox in my td5 defender. Positioned under the drivers seat. And while at it, I've been learning some of the land rover electrics.
I came across this un-used plug and looked into the wiring diagrams to find it was the glowplug relay plug.
Any ideas why this would have been removed or not fitted? I'm guessing I've had no power to the glow plugs for some time?
Last year plugs were removed to test them and they were fine.
Is it a special type of relay?
Thanks and merry Christmas all
Post #874152 22nd Dec 2020 11:34am
Martin
Site Admin
70A relay needed Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #874156 22nd Dec 2020 11:59am
hank
Worth trying a relay in there. Think the part number is YWB500220
Not certain whether the same on a TD5 but for TDCi also check fuse 38.
Does make you wonder who removed it though and more importantly why? > 110 XS Double Cab
Post #874228 22nd Dec 2020 8:05pm
souster4
Thanks chaps will give it a go and see what happens.
I've still had the glow plug light ignite on the dash though?
Post #874500 24th Dec 2020 11:05am
Martin
Site Admin
Glow lamp control and glow relay control are separate ECU functions.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #874502 24th Dec 2020 11:07am
landy andy
I would test with a meter first, before just poking a relay in.
Post #874519 24th Dec 2020 1:32pm
Mo Murphy
How did you test them without a relay ?
50 Shades of Pennine Grey
Post #874531 24th Dec 2020 2:53pm
landy andy
Check you’ve got 12V to relay carrier, check the resistance on the wire out to the blow plugs isn’t a short direct to earth. Check that the glows plugs aren’t already getting 12v from some other source or you've miss diagnosed the relay carrier.
You could disconnect the wire to the glow plugs and put a test bulb into the system instead.
Post #874534 24th Dec 2020 3:23pm
souster4
Thanks very much chaps. Hope you had a good Christmas.
I tested the glow plugs with jump leads on the bench, they are perfect.
I'll do some multimeter testing I think, instead of just chucking a relay in. Tis strange no relay I think
Post #874753 26th Dec 2020 9:43pm
hank
I'll be interested to hear your findings > 110 XS Double Cab
Post #876586 6th Jan 2021 10:38am
