Home > Puma (Tdci) > Dim Dip |
robrennie Member Since: 20 Mar 2018 Location: Somerset Posts: 28 |
With the advice of llessur this one is solved.
Although the relay for TDCi is more complicated than on previous Defenders - the bypass relay still works. On the below link you will see the pics for it. https://www.defender2.net/forum/topic76071.html |
21st Dec 2020 8:42pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17515 |
Alternatively you can reach under the driver's side front wing adjacent to the radio aerial and simply unplug the dim dip resistor, and leave the relay alone. The zero cost option!
21st Dec 2020 9:19pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20545 |
^^^^ This is what I did.
I sealed the rear entries of new connectors and fitted those to blank off the unplugged connectors too. Saves leaving them just unplugged and left “open air” even if they won’t be used again. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
21st Dec 2020 9:24pm |
Worth remembering too that if you unplug the dim dip resistor, and then subsequently Lucas, Prince of Darkness takes your headlights away by melting the light switch at an inconvenient moment, you can simply short the terminals of the disconnected resistor connector (in effect putting a near-zero Ohm resistor in the circuit) as as though by a miracle you'll have full power dip beam whenever the sidelights are on.
Lucas, P.o.D., will be defeated! |
21st Dec 2020 9:32pm |
Just to close this off - I have fitted the replacement relay and the system works as it should.
So although the Puma Dim Dip relay is more complex that the previous versions, Part Number YWZ10003L cures the problem. Thanks guys for the DIY suggestions, I have not tried them as I had already ordered the part. |
23rd Dec 2020 4:00pm |
