Home > General & Technical (L663) > £30k New Hilus has this , why not my £60k Defender |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 |
It’ll be to save Da Planet. If you saw that you might keep driving for a few miles and let the cycle finish, which obv would mean you’ll cause the end of the polar bears single handedly.
My Karoq is the same, but only cost £21k. |
13th Dec 2020 12:17pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3350 |
I remember looking in my D5 manual and it said a green light should come on after a successful regen, never saw it once.
It’s pretty easy to tell when the cars going through a regen as there’s a nice deep exhaust note. Last edited by J77 on 13th Dec 2020 12:42pm. Edited 1 time in total |
13th Dec 2020 12:35pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4149 |
Toyotas in some market have a DPF regen button on the dash so you can actually choose when it does it. 2007 110 TDCi Station Wagon XS
13th Dec 2020 12:42pm |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 323 |
That button sounds a really useful feature. The number of times my puma decides to start an active regen just as I'm nearing the end of a journey!
13th Dec 2020 1:31pm |
Telemarkskier Member Since: 20 Jul 2020 Location: Wiltshire Posts: 121 |
Yes fully concur with that thought. Perhaps an update to Pivi Pro can be made as I notice in the I guide that it states that the exhaust filter lamp briefly illuminates when a successful filter regeneration process has been carried out. 2020 Defender 110 SE 240D: Fuji White.
2011 Freelander 2 SD4 HSE 2007 Freelander2 HSE (man) |
13th Dec 2020 3:57pm |
weeman Member Since: 13 Sep 2020 Location: AUS Posts: 8 |
Attached image is from the manual. I haven't had mine long enough for a DPF burn, would be interested if other owners have seen this light up after a DPF regen.
Click image to enlarge |
14th Dec 2020 12:24am |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Never seen that light flash Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
14th Dec 2020 12:35am |
Logannz Member Since: 29 May 2020 Location: Queenstown Posts: 26 |
Our little Hino delivery truck gives you a count down to needing a re-gen, so yo can manually trigger one early if it suits better.
14th Dec 2020 3:03am |
Karlowse Member Since: 06 Dec 2020 Location: West Midlands Posts: 13 |
The new transit custom has this setting it gives you a percentage and you can set it to sit at two and a half thousand to clear the dbf. Even though it’s new when it builds up it chucks out some white smoke.
14th Dec 2020 8:19am |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2587 |
There was something on You Tube a while back about this in Australia. Toyota was having massive problems with the DPF and hence the regen button was added. More a sticky plaster than a fix..... |
14th Dec 2020 11:36am |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 677 |
Technically..... all the lights, all the notifications, are a failure of the vehicle to manage its DPF successfully so that it's existence is transparent and invisible to the operator.
Thus the reason why luxury manufacturers won't add a lamp unless there's a fault. It should, be entirely invisible to the operator. Only in certain circumstances like vehicles that idle for extended periods etc, should one technically be needed, and even then, it's perfectly possible to regenerate a DPF at idle as long as it's managed correctly. So whilst it's helpful for us savvy operators to know its happening so we can "look after it and keep it running long enough for it to finish", that's not the goal of the manufacturer. |
14th Dec 2020 12:25pm |
Philip Member Since: 09 Mar 2018 Location: England Posts: 510 |
Yes, big problem for them: https://www.caradvice.com.au/895387/reveal...r-filters/ |
14th Dec 2020 12:46pm |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 |
Fully agree. A system well set up does not need to have manual activation button nor any information displayed in order to prevent process interrupt. |
14th Dec 2020 3:15pm |
