Home > General & Technical (L663) > £30k New Hilus has this , why not my £60k Defender
Tim in Scotland
A DPF regen warning message and gong is fitted to the new Toyota Hilux pick-up (and probably a load of other Diesel engined Toyotas) so how come Land Rover cannot add one to any of their luxury cars? Might save a lot of DPF issues caused by drivers switching off the engine before the regen has completed causing oil dilution..... and a premature “Service Required” message on the dash.
 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #872698 13th Dec 2020 10:58am
DSL
It’ll be to save Da Planet. If you saw that you might keep driving for a few miles and let the cycle finish, which obv would mean you’ll cause the end of the polar bears single handedly. Thumbs Up
My Karoq is the same, but only cost £21k. Whistle
Post #872702 13th Dec 2020 11:17am
J77
I remember looking in my D5 manual and it said a green light should come on after a successful regen, never saw it once.
It’s pretty easy to tell when the cars going through a regen as there’s a nice deep exhaust note.
Post #872705 13th Dec 2020 11:35am
Bluest
Toyotas in some market have a DPF regen button on the dash so you can actually choose when it does it. 2007 110 TDCi Station Wagon XS
Post #872710 13th Dec 2020 11:42am
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
That button sounds a really useful feature. The number of times my puma decides to start an active regen just as I'm nearing the end of a journey! Smile
Post #872720 13th Dec 2020 12:31pm
Telemarkskier
Yes fully concur with that thought. Perhaps an update to Pivi Pro can be made as I notice in the I guide that it states that the exhaust filter lamp briefly illuminates when a successful filter regeneration process has been carried out. 2020 Defender 110 SE 240D: Fuji White.
2011 Freelander 2 SD4 HSE
2007 Freelander2 HSE (man)
Post #872739 13th Dec 2020 2:57pm
weeman
Attached image is from the manual. I haven't had mine long enough for a DPF burn, would be interested if other owners have seen this light up after a DPF regen.
Post #872802 13th Dec 2020 11:24pm
Tim in Scotland
Never seen that light flash Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #872803 13th Dec 2020 11:35pm
Logannz
New Zealand
Our little Hino delivery truck gives you a count down to needing a re-gen, so yo can manually trigger one early if it suits better.
Post #872805 14th Dec 2020 2:03am
Karlowse
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
The new transit custom has this setting it gives you a percentage and you can set it to sit at two and a half thousand to clear the dbf. Even though it’s new when it builds up it chucks out some white smoke.
Post #872810 14th Dec 2020 7:19am
markb110
There was something on You Tube a while back about this in Australia. Toyota was having massive problems with the DPF and hence the regen button was added.
More a sticky plaster than a fix.....
Post #872831 14th Dec 2020 10:36am
Matt110
Technically..... all the lights, all the notifications, are a failure of the vehicle to manage its DPF successfully so that it's existence is transparent and invisible to the operator.
Thus the reason why luxury manufacturers won't add a lamp unless there's a fault. It should, be entirely invisible to the operator.
Only in certain circumstances like vehicles that idle for extended periods etc, should one technically be needed, and even then, it's perfectly possible to regenerate a DPF at idle as long as it's managed correctly.
So whilst it's helpful for us savvy operators to know its happening so we can "look after it and keep it running long enough for it to finish", that's not the goal of the manufacturer.
Post #872839 14th Dec 2020 11:25am
Philip
Yes, big problem for them:
https://www.caradvice.com.au/895387/reveal...r-filters/
Post #872843 14th Dec 2020 11:46am
Sepp
Germany
Fully agree.
A system well set up does not need to have manual activation button nor any information displayed in order to prevent process interrupt.
Post #872866 14th Dec 2020 2:15pm
