Home > Puma (Tdci) > Defender 110 2.2 2013 Gearbox
audi1boy
United Kingdom 2008 Defender 130 Puma 2.4 HCPU Barolo Black
Afternoon all,
Have a 2013 110 Double cab Defender.
It had a new clutch about 6 months ago and with it a new clutch release bearing.
Then a few weeks ago i noticed that there was a worn bearing noise when you lifted/engaged the clutch in neutral. I pulled the gearbox and replaced the clutch release bearing again. But it has come back worse than ever.
When the vehicle is cold its ok but when its up to temp its quite loud when you engage the clutch/lift the pedal.
I have tried the stop the engine trick to see if its the springs on the clutch but its fine.
Will it be the input shaft bearing on the gearbox? Will it be worth getting the transfer box remanufactured at the same time if the bearing has gone?
TIA
Post #872450 11th Dec 2020 4:45pm
JOW240725
I'm afraid I can't help with your queston but sure some experts will be along shortly. But welcome to D2N Thumbs Up James
Instagram @suffolk_rovers
Post #872461 11th Dec 2020 5:25pm
Dinnu
When you press the clutch pedal, the clutch release bearing is working, and all gearbox bearings would stop or at least slow down. All gearbox bearings will stop once you engage a gear and the vehicle is still stationary.
On the other hand, the input shaft is rotating, but so is the layshaft and all the gears inside the gearbox when the clutch pedal is released. With clutch pedal released, the clutch release bearing is not rotating (at least not under load).
So from your description I am afraid it could be the gearbox.
Have you dropped the oil to check the quality of the oil? If you re fill it, everyone states to refill 2.2liters. My manual says 2.4liters (2012). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #872463 11th Dec 2020 5:34pm
