![]() | Home > Tdi > Rear cross member holes |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 364 ![]() ![]() ![]() |
A,b,h and i is for the rear "step" handle thingies that was on the older versions.
C and d is used for the support that fixes on to the bottom of the rear of the tub. I think they will have a tube thingy inside the cross member to prevent the steel from collapsing. |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
From your diagram -
A B + H I, are for the civilian 'grab handle' rear bumperettes - ![]() C D + F G, are for the military rear bumperettes - ![]() Click image to enlarge E + one you've missed on the body mounting tab, are for the military lifting/lashing shackle mounting - ![]() Click image to enlarge J + K, are for the drop-down tailgate hinges - ![]() . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 6th Dec 2020 9:38pm. Edited 1 time in total |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
Wow, fantastic responses in double quick time!
Thanks guys, I really appreciate your help. I really could not figure out what these were all for, but when you see all the different equipment bolted on to these at some time it brings home the versatility of the truck! Thanks again. Mick |
I meant to say that I don't know what L and M are for, as I don't have those on my pre-Tdi crossmember -
![]() Click image to enlarge . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17728 ![]() ![]() ![]() |
L and M aren't present on my Puma cross member either, although all the others are including the one you missed.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
J and K are used for the drop down pickup door. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
