![]() | Home > Puma (Tdci) > Puma cuts of in 6th gear uphill ! |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
Maybe the fan needs a smaller pulley to speed it up. That would give the same effect as running in a lower gear. When I had this problem in the Spanish heatwave last year, I found that running in a lower gear and keeping the revs high helped. 2007 110 TDCi Station Wagon XS
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 ![]() ![]() ![]() |
In this Country I’ve never had an issue,
Only when driving in Spain, Portugal or Italy. Here it doesn’t get hot enough, unless you are towing and I don’t tow anything heavy. Fabio |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
If you haven’t done the thermostat mod that’s first port of call 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Alex von Staffeldt Member Since: 06 Nov 2017 Location: Copenhagen Posts: 57 ![]() ![]() ![]() |
Just changed the waterpump, CHT sensor, fan spacer, thermostat & radiator. Took her for a ride and now there is no heat when gearing down or when idle !
Anyone has had the same problem. Now im going for a longer ride to see if it cuts of in 6th gear.. FINGERS CROSSED. Defender 110 Puma 2.4 tdci |
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327 ![]() ![]() |
Hope it goes well!
Fingers crossed! |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Same problem here for a loooong time.
As described 6th gear 120 KPH mild long slope up hot days (>35C) After certain time, temperature increase to 112-115C and the engines going to limp mode. Cylinder compression is normal and no coolant consumption I have already changed the thermostat, I have the fan spacer, a new enhanced radiator and intercooler and the temperature has been drop compared to the initial situation, but still happens. I have a preset alarm in my ODCBII reader when the temperature going over 110C to avoid the trouble reducing speed to 100 KPH when all bach to normal 90-95C Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
UPDATE !!
Hello Guys... Just went for a 100 km ride with various driving. Up hill in 130 kmt and nothing happend. Some times as much as 140 kmt !!! Is has certainly worked for the Lady. Putted in 300 kg of sandbags in the back of the landy to simulate towing. I am so happy for the difference. Defender 110 Puma 2.4 tdci |
That’s good news!
I’ll change my rad, thermostat and CHT and see if that fixes my issue. |
I hope that it will keep like this, and that it fixes your issue as well.
Il keep my fingers crossed. Defender 110 Puma 2.4 tdci |
Took a long drive from Jutland to Sweden yesterday. Normally she cuts of when going 100 kmh.. Now i can drive 110-120 without cutting off. I had one incident when i was driving up hill for 3 km. I wanted to overtake another car driving 100kmh and when i reached 125kmh she cut out. Thats totaly fine with me. Normally i drive 100-105 kmh and now she dosent cut out at that speed. The conclusion is that it has really helped and no i just enjoy that i can overtake cars driving 90 on the motorway without cutting out. Defender 110 Puma 2.4 tdci |
Thanks for the update!
Thats positive! I have now ordered the rad, thermostat and CHT so will hopefully fit next week. I did change my VCV today which I think has made it sound better and it certainly feels smoother than before. I don't think it's fixed my issue but I'll do a run tomorrow just to check. Do you happen to have live stats? If you do it would be interesting to hear what temp yours now sits at when cruising. |
Hi Greyman110.
Sorry i dont have live stats. I think i will change my VCV as well. Maybe with a little luck it will make mine sound better also ![]() |
[quote="Greyman110"]Thanks for the update!
Took a ride out hunting today. No heating in the cabin AT ALL !! Have you experienced that ? Defender 110 Puma 2.4 tdci |
I had it blowing hot and cold.
First check the coolant level on cold. Next check the white plastic heater valve at the back of the engine after the car has warmed up to make sure coolant is getting up to it. I made my heating better by starting the engine and doing a bleed. I then drove it to get it up to temp and I bled it again through the bleed screw with the engine on. WARNING - When you do this boiling coolant can spray everywhere! I cut the the top off a water bottle and put a notch in the side so it would go over the pipes. I then used the bottle top opening to put a screw driver in to undo the bleed screw. I used the bottom half of the bottle to catch run-off so I could also inspect it. * If you had a garage fit do the recent work, they would have had to empty the cooling system. They should have refilled it and then followed the recommended landrover instructions. |
