Home > In Car Electronics > LED bulb for interior lights
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
The bulb in the rear of my 2009 USW died so I thought why not replace with an LED
Got this from ebay Item number 163631838485
Advertised as
Interior Light x2 CREE Chip LED 15W Upgrade Bulb Land Rover Defender 90 110
Lumens: 250 (standard bulb is 50 Lumen)
It is dimmer than a firefly sitting on the roof lining.
Any decent ones out there?
Post #870188 28th Nov 2020 9:37pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Did you try turning the bulb around in the interior light fitting to see if it’s any brighter?
I think some of these LED bulbs are sensitive to which way round they are fitted.
I’m sure someone on here will be along to provide a better explanation soon.
Post #870196 28th Nov 2020 10:39pm
Naks
speaking of interior LEDs, how easy is it to replace the dashboard lights, especially the one behind the aircon controls? --
Post #870216 29th Nov 2020 6:31am
I've got these fitted and whilst not the cheapest, they are brilliant:
https://www.conrad-electronic.co.uk/ce/en/...AREA_22519 Darren
Post #870234 29th Nov 2020 9:17am
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
I bought from https://fourby.co.uk, 3 for £6.99, the difference was like night and day....literally
Regards
Rob
Post #870240 29th Nov 2020 10:09am
kmac
Thanks all, will try the Forby ones.
The Conrad Electronics ones are no longer available. I did try and source those before I got my current ones as I did a search on here.
Post #870245 29th Nov 2020 10:47am
williamthedog
Why don't you have a look at the mudstuff led light. Ok it's expensive but works a treat and you can change between white and red also.
Post #870249 29th Nov 2020 11:04am
donmacn
^^^ I did this, just because I'd tried one of the cheap LED 'panels' in the original fitting before, and while it worked OK, it had some odd behaviour - glowing after being switched off and sometimes staying on. Probably an earth fault somewhere.
But - to get back on topic - when I dropped and refurbed the roof lining I thought I'd try the MUD ones. I thought the red light would be a bit of a 'gimmick' that I wouldn't actually use much, but it's become the default setting so that when I switch it on, I don't get the "ouch" factor of bright white light. Particularly because we live in a semi-rural area with quite low levels of external light.
Then if I find I need to, I can always put the white on. Anyway, I find I use the red light more often which has been a bit of a surprise. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #870250 29th Nov 2020 11:25am
Ah, that's a shame. Useful to know, though. Darren
Post #870291 29th Nov 2020 5:05pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
3 55 lumen LED's in the rear speaker panel light up the cargo area quite well.
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #870309 29th Nov 2020 6:43pm
😎👍🏻 $W33T $0U7H3RN $UG4R
Post #870311 29th Nov 2020 7:10pm
Martyn668
+1 for the Fourby ones.
Post #872619 12th Dec 2020 5:24pm
kmac
For anyone interested, Classic Car LEDs (a lot of us including me have bought their headlight LEDs) also sell the festoon lights for about £2 delivered
I have obtained two, they seem a little shorter than the original but the contacts on the light fittings can be pushed forward to grip the bulbs
Post #872666 12th Dec 2020 9:41pm
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
I’ve just grabbed a pair from the Classic Car guys; much brighter and they do the dimming thing when you lock it.
My advice would be to disconnect the battery before attempting the job. I know it’s best practice, but I didn’t bother and managed to blow the fuse (which annoyingly feeds the radio too, so need to dig out the code).
The bulbs are shorter, but I bent the prongs so it fits nicely. 2011 CSW XS 90
Post #875078 29th Dec 2020 5:51pm
DAZ110
What is the part number for the Classic Car interior light bulbs ?
Post #875106 29th Dec 2020 8:08pm
