Home > In Car Electronics > LED bulb for interior lights |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2038 |
Did you try turning the bulb around in the interior light fitting to see if it’s any brighter?
I think some of these LED bulbs are sensitive to which way round they are fitted. I’m sure someone on here will be along to provide a better explanation soon. |
28th Nov 2020 10:39pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
speaking of interior LEDs, how easy is it to replace the dashboard lights, especially the one behind the aircon controls? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
29th Nov 2020 6:31am |
I've got these fitted and whilst not the cheapest, they are brilliant:
Click image to enlarge https://www.conrad-electronic.co.uk/ce/en/...AREA_22519 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
29th Nov 2020 9:17am |
G4UJS Member Since: 20 Jan 2019 Location: Shropshire Posts: 226 |
I bought from https://fourby.co.uk, 3 for £6.99, the difference was like night and day....literally
Regards Rob |
29th Nov 2020 10:09am |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Thanks all, will try the Forby ones.
The Conrad Electronics ones are no longer available. I did try and source those before I got my current ones as I did a search on here. |
29th Nov 2020 10:47am |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Why don't you have a look at the mudstuff led light. Ok it's expensive but works a treat and you can change between white and red also.
29th Nov 2020 11:04am |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
^^^ I did this, just because I'd tried one of the cheap LED 'panels' in the original fitting before, and while it worked OK, it had some odd behaviour - glowing after being switched off and sometimes staying on. Probably an earth fault somewhere.
But - to get back on topic - when I dropped and refurbed the roof lining I thought I'd try the MUD ones. I thought the red light would be a bit of a 'gimmick' that I wouldn't actually use much, but it's become the default setting so that when I switch it on, I don't get the "ouch" factor of bright white light. Particularly because we live in a semi-rural area with quite low levels of external light. Then if I find I need to, I can always put the white on. Anyway, I find I use the red light more often which has been a bit of a surprise. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
29th Nov 2020 11:25am |
Ah, that's a shame. Useful to know, though. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
29th Nov 2020 5:05pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
3 55 lumen LED's in the rear speaker panel light up the cargo area quite well.
Click image to enlarge Click image to enlarge it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
29th Nov 2020 6:43pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20356 |
😎👍🏻 $W33T $0U7H3RN $UG4R
29th Nov 2020 7:10pm |
Martyn668 Member Since: 17 Mar 2013 Location: Cambridgeshire Posts: 135 |
+1 for the Fourby ones.
12th Dec 2020 5:24pm |
For anyone interested, Classic Car LEDs (a lot of us including me have bought their headlight LEDs) also sell the festoon lights for about £2 delivered
I have obtained two, they seem a little shorter than the original but the contacts on the light fittings can be pushed forward to grip the bulbs |
12th Dec 2020 9:41pm |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 |
I’ve just grabbed a pair from the Classic Car guys; much brighter and they do the dimming thing when you lock it.
My advice would be to disconnect the battery before attempting the job. I know it’s best practice, but I didn’t bother and managed to blow the fuse (which annoyingly feeds the radio too, so need to dig out the code). The bulbs are shorter, but I bent the prongs so it fits nicely. 2011 CSW XS 90 |
29th Dec 2020 5:51pm |
What is the part number for the Classic Car interior light bulbs ?
29th Dec 2020 8:08pm |
