Home > My Defender > CDN 038's Niagara Grey 110 Td5... ongoing upgrades
Page 13 of 13 <123 ... 111213
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Sometimes it's the unseen things that bring satisfaction. For probably 3 years now, the dreaded Td5 "squeak " has announced my arrival every time I turn off the engine.SQUEEK! Embarassed
There's no sneaking home late at night being unheard. Every time I stop to fuel up, I tun heads fro the wrong reason. SQUEEK! Embarassed
I've delayed it long enough....but I want to spend money on FUN stuff....not things that don't improve performance, or comfort, or aren't some sort of upgrade...
Well, I bit the bullet, had it changed. It's so strange to not have that familiar announcement of my arrival, for the first day it almost felt as if something was wrong. Laughing it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #869741 26th Nov 2020 4:37pm
kenzle8a
for us TD5 noobs, what is the squeak?
Post #875191 30th Dec 2020 1:06pm
CDN38
Harmonic balancer (crank damper).
The rubber ring between the center pulley and outer steel ring starts to wear. When you stop the engine, the inner (or outer) slips on the rubber and it squeaks..... almost more like a chirp. All a distant memory now Laughing it's a Landrover thing...
Post #875286 30th Dec 2020 6:50pm
kenzle8a
Ah another thing to keep an eye on then... I've been working my way through my TD5's list of squeaks, rattles, taps, clonks and dunks...
Post #875296 30th Dec 2020 7:20pm
Joel
United Kingdom 2002 Defender 110 Td5 DCPU Santorini Black
I have the same, is it an easy job?
Post #875308 30th Dec 2020 8:01pm
CDN38
I had it done at my local shop. Too busy and pre-occupied with other things to figure it out.
From what I seem to recall, the main bolt is often Evil or Very Mad to get off. Pretty sure you need to pull the rad fro easier access. If you have a hoist, you can approach from the underside with a big breaker bar...
For me, it was money well spent to get it done. it's a Landrover thing...
Post #875578 31st Dec 2020 10:50pm
fragrantpustule
Canada 2003 Defender 110 Td5 SW Coniston Green
Just here to say, this thread is incredible. Really enjoyed following along with your build. Thanks for sharing!
Post #988875 13th Apr 2023 7:42pm
