Home > General & Technical (L663) > WiFi issues |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Have a look to see if you car has received an OTA software update last Friday. Then check in the connectivity/ connections page to see if it has reset the the WiFi hotspot and WiFi connections off or changed their settings. Next step is to try a PiviPro reset by pressing down and holding down for 10-15 secs the power button/knob for the audio on the dash ( far end on the passenger side that is). The system will reboot which only takes a couple of minutes but you won’t be able to select any pages in the settings menu until the SatNav shows your location on the big screen. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
25th Nov 2020 5:06pm |
Flemincc Member Since: 21 Nov 2020 Location: Cincinnati, OH Posts: 8 |
Yes it did get an update on the 19th....
25th Nov 2020 5:09pm |
I did the system
Reset and the WiFi is still stuck on searching for networks, the thing just spins and never finds any networks |
25th Nov 2020 6:02pm |
