![]() | Home > Puma (Tdci) > Rear demister voltage sensitive switch? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
No VSS on the rear heated screen wiring on a Puma, not sure when LR stopped fitting them but they haven’t been on for a very very long time!
There is a timer/enable unit on the FRONT screen, perhaps this is what you’ve seen? There is a normal relay so check this is working ok (perhaps by swapping over with another of the same). ![]() ![]() |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 ![]() ![]() |
Please don't forget to check for broken wiring in the convoluted rubber grommet / tube between the door and body tub, if you have not done so already.
cypermethrin Member Since: 15 Dec 2010 Location: Berkshire Posts: 93 ![]() ![]() ![]() |
Solved! No wonder the ground was shoddy - was trying to get thru the hinge plus everything else frayed... further back than I looked.
repaired and did the rear window lamp where it rubbed through too. Thanks for the suggestions, the breaks were behind the plastic speaker housing, I briefly scoped the circuit and it was awful so assumed it was further back as the door was alright in the end. Onto the next fault! |
Glad you got it fixed .
Although it's frustrating when things stop working, it's satisfying when you get it sorted. |
