![]() | Home > Wheels & Tyres > Smallest Wheels Possible |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3654 ![]() ![]() ![]() |
15 inch wheels and low profile tires will drop you massively DEFENDER 90 TDCI XS,
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 ![]() ![]() |
It looks like a sausage dog
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1822 ![]() ![]() ![]() |
just a set of old gash steels, no tyres?
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3564 ![]() ![]() ![]() |
In the same way they transport monster trucks
![]() What is your truck height with lift and rack and what is your maximum garage door height? If your garage floor is flat, and you don’t have far to move it, you could buy some second hand steel rims and dispense with the rubber - and give it a push in |
You beat me to it ickle
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 431 ![]() ![]() ![]() |
All great ideas! Thanks Gents!
I'll have to have a measure up and see what works. I know that when a Max Height sign is at 2.2m it hits the sign, but 2.4m i can fit under. ![]() Now to find some scrap wheels with a LR stud pattern.. |
At my last house, it had a double garage with up and over doors, I found if I screwed the one door shut by its original transport points and then removed the screws holding the frame to the brickwork, I could slide it across behind the other door and there was just enough height to get the 100" in and slide the door closed behind.
Once in, there was just enough height to jack it up, remove the wheels and lower onto some improvised skates. HTH Keith |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2655 ![]() ![]() ![]() |
What about the original Ninety / Discovery steels with the 205 tyre?
Could always let some air out as well..... |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 639 ![]() ![]() ![]() |
Some road cars use "undersized" spare wheel, with some really low profile tire on it... "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 ![]() ![]() ![]() |
There are Ifor Williams wheels with the same stud pattern which give you about the result as the OP posted. I remember having seen a picture of a belgian club member who put his offroader on these small wheels to trailer it through the chunnel IIRC. You'll need to use a spacer to clear the brakes though.
Can't find the pic unfortunately. There's some more detail in this topic on lr4x4. Edit: The original pic is gone, but I managed to make a screenshot from the google search results, I presume it is cached ![]() Click image to enlarge J Antares Treadwell, a MY06 110 Td5 in Chawton White |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
As above, a lot of 13" Ifor Williams wheels are 5x165 PCD with M16 studs.
Probably goes like stink but tops out at about 40mph ![]() Otherwise a 15x7 wheel with a 195R15 on it, or maybe 15/16" with a low profile car tyre on. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Thanks for all the replies on this gents. The ifor williams stud pattern tip is the one I'll now try, as I have access to a trailer with them on.
I'll post a before and after with measurements when I give it a go! ![]() |
