![]() | Home > Puma (Tdci) > New door seals choice for 2007 Puma |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
I have found my door seals are in very poor state - will have to replace all of them.
Is there any recommended seals set from what is available? If it can improve dust-ingress would be perfect. Kind regards, Janusz www.yahodeville.com |
vogue se Member Since: 24 Jan 2008 Location: Bocholt Posts: 112 ![]() ![]() ![]() |
I had different doorseals on my 2007 Defnder as on my 2011.
The 2011 frontdoorseals had an extra lip on the front bottom corner. and that gives less dust in the car. |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 199 ![]() ![]() ![]() |
As above, go genuine and you won't go wrong.
You can retrofit the new bottom door seals to older doors, (Part number LR029309 for front doors, not handed, Part numbers LR029307 & LR029308 for middle row in a 110), this involves drilling some holes in the bottom of the doors as the fixing do not align with older ones, but in the end they seal tighter and you won't see daylight through the bottom corners anymore ![]() /Mat |
keef9t Member Since: 13 Mar 2016 Location: manchester Posts: 183 ![]() ![]() ![]() |
Have a look at Britannica Restorations youtube videos. He does a comparison and the conclusion is go genuine.
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1984 ![]() ![]() ![]() |
Genuine is far superior to other makes and will outlast them trust me i know!
Dan who used to work at Duckworths gave me some great prices but his replacement may do so too 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17712 ![]() ![]() ![]() |
Oh no! ![]() How does the water escape? ![]() Last edited by blackwolf on 20th Nov 2020 11:35am. Edited 1 time in total |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 287 ![]() ![]() ![]() |
Just done mine with genuine and the modified bottom seal. Came out to five times the price of pattern parts but worth the extra.
For the modified seal I only had to drill two holes per door for the parts that come round the corners and go vertical. Check strap has to be detached to open the door wide enough to drill. New seals have made a huge difference to my truck. 2011 130 Utility Body 2005 110 Van |
Thank you for showing me the way forward
![]() www.yahodeville.com |
