Home > Td5 > White/Grey Smoke -Start Up & Strong Diesel Smell When Dr
LandyHelp
Hi all,
I have recently had the glow plugs replaced at huge cost in my 2005 TD5 to improve acceleration. It seems to have worked and is better but I am still starting the car 2 to 3 times in the morning when starting the car. The weather here is hot all the time so this cannot be it.
There is also grey smoke immediately coming out of the exhaust after the car has started up. Any thoughts?
Second item - which although the car has been back in the garage lots and lots and lots of times, still smells of strong diesel when driving it. The garage clearly are not able to diagnose the issue!
Yours chokingly a very baffled 110 TD5 driver!
Post #868287 19th Nov 2020 2:39pm
jst
Fuel leak into cylinder or water leak into cylinder , lack of compression?
Is vehicle pressurising expansion bottle?
Is the grey definitely smoke or clouds/vapour
is it using engine oil.
Does the smell of fuel stay with you on say an hours drive or it it just there after starting?
Changing glow plugs is unlikely to improve acceleration unless a plug was missing. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #868296 19th Nov 2020 3:08pm
excossack
Injector seals?
Oil in the red plug at the ECU?
MAF sensor? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #868302 19th Nov 2020 3:26pm
LandyHelp
Thanks JST and Excossack. I was hoping the glow plugs would improve start up. Noted regarding the acceleration. Just worn out so replaced.
I will have a look at the seals, oil in the red plug at the ECU (no check engine light on though), and MAF sensor.
The smell of diesel stays on in the car although I do short journeys, so maybe the car needs a good run.
The entire engine was flushed out due an incorrectly installed liquid oil gasket resulting in a mess of oil and coolant mixing together but this was all cleared up.
Post #868308 19th Nov 2020 3:58pm
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
Check the fuel pressure regulator is not leaking as this can cause a strong smell of diesel in the cab and if it’s causing a pressure drop hard starting
Post #868315 19th Nov 2020 4:19pm
excossack
A bottle of injector cleaner and a good run might be just the ticket? 1999 Defender TD5 110
Regards
John M0VAZ
Post #868316 19th Nov 2020 4:20pm
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
injector seals...use genuine!
Post #868412 19th Nov 2020 8:33pm
lightning
l had a strong smell of diesel fumes in my 2005 110 when l first bought it.
l never really got to the bottom of it, tried all manner of things, but for some reason it no longer does it. lt seemed to be worse when the heater was set to hot, leading me to change the heater/bulkhead seal but that didn't cure it.
Replacing the CAT seemed to make a difference but it's an expensive option, l've got a spare CAT down pipe that was bought new and only did 12,000 miles if you want to try that.
Post #868461 19th Nov 2020 11:05pm
