Home > Technical > Is it my starter or bad earth ? NOW SORTED .
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Got the dreaded very slow turn over then on second try it’s ok ish , and sometimes won’t even turnover it just makes a noise and clicks like a bad earth or not enough power !! ,
Now fitted new battery as unsure of age and still the same problem , I guess it’s time to put it on the ramp and have a look
Stew
Post #867846 17th Nov 2020 7:16am
AJC
I would say poor connection, but starters can fail due to swarf from the DMF if thats going too, dependant upon mileage, use etc
Post #867847 17th Nov 2020 7:17am
stew 46
2010 77,000 and very light use Thumbs Up
Post #867849 17th Nov 2020 7:20am
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Connect a jump lead from starter casing to chassis or battery neg and try it. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #867857 17th Nov 2020 8:22am
stew 46
I’ll give it a go later Dave Thumbs Up
Post #867858 17th Nov 2020 8:25am
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
check the main earth from the battery that connects to the transfer box, that was the issue on my 2014 plate
Post #867927 17th Nov 2020 5:23pm
stew 46
Had it up on my ramp earlier and it started 10 times in a row then on the 11th it was like the starter not getting enough power , so then put jump lead from starter to a good earth and the same started about ten times then like lack of enough power and starter not throwing enough Big Cry , when the starter works its spot on so makes me feel it’s an earth problem!! But still a head scratcher Rolling Eyes
Will try and get an hour on it tomorrow
Post #867944 17th Nov 2020 7:10pm
Bian Considine
It could be a "dead" spot on the commutator &/or sticking carbon brushes.
Post #867993 17th Nov 2020 10:58pm
Two candidates likely to be the issue is as already suggested main Earth lead to T box.
Or loose battery clamps.
Also worth checking the clamp assemblies and fuses that nothing is blown or especially loose including cable lugs and bolts.
It is likely to be around the battery and it’s connections that is your issue as these were the areas disturbed and probably not the starter.
Are you sure the battery is good and the voltage is correct and ready to go?
If the battery is not the correct voltage in the first place and well charged that maybe an issue too.
It should read at least 12.2v. KEEP CALM AND Drill ON
Post #867997 17th Nov 2020 11:40pm
dorsetsmith
as ^^^
Only applicable to pre 07 land rovers
I be having good look at that starter motor
may you have same problem that later starter motor have i.e. coil main heavy switch contacts pitted you can get replacement solenoid but have and look at commutator and carbon brushes. before replacing it as commutator may not be serviceable
Land Rover Defender Discovery 1 200 300Tdi Starter Motor Solenoid STC1245
STC1246
Box assembly-brush starter motor,
STC1254
Spring-coil
________________________________________________________________________________________________
Its ford thing that your problem not serviceable scrap and start again
Post #867998 17th Nov 2020 11:45pm
stew 46
I fitted a new battery Sunday and it’s reading 12.5 and 14.4 when running so I know that’s good
I’ll have good go at the earth today Thumbs Up
Thanks for the info Bow down
Post #868023 18th Nov 2020 6:49am
Martin
Site Admin
Stew change your Defender profile as it's got the 300 Tdi in it!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #868044 18th Nov 2020 8:45am
stew 46
Done Thumbs Up
Post #868047 18th Nov 2020 9:01am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
12.5 is pretty low if that is the settled voltage e.g. after sitting overnight with no load on it. A fully charged new battery I would expect to show more like 12.85v settled and the voltage charging is just what the alternator is putting out so all that means is the alternator is working fine. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #868058 18th Nov 2020 9:59am
I wonder if there is any issue with the plates in the battery?
In an ideal world, pity there isn’t a second battery to check just in case but that’s not really feasible.
Have you tried hooking it up to read voltage during cranking to see the extent of voltage drop? There is usually a fairly significant voltage drop on Defenders anyway during cranking but could be a sign to keep an eye out for. Any lower than 8v during cranking I’d say maybe an issue.
Have you tried the old battery again or is that not available now? KEEP CALM AND Drill ON
Post #868109 18th Nov 2020 1:19pm
