Home > Puma (Tdci) > Switches
Ninja man
Switches
Hi , fitting a work light to my 2014 puma ,wiring all in now but have found the bearmach switch is sticking when used in place of blank on top left of dash but is ok when not in position.has anyone found this as it appears to be the dash hole squeezing the switch.hope I’ve explained the problem well enough. Crying or Very sad
Post #867138 13th Nov 2020 6:05pm
Martin
Site Admin
Is it a really hard push to fit in place compared to the blank?
If so you may need to remove the "key" tab from the body of the switch so it goes in square and not wonky Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #867139 13th Nov 2020 6:09pm
Ninja man
What is the key tab do you have any pictures,I’m not to familiar with the switches as first time playing with dash ,cheers
Post #867150 13th Nov 2020 7:13pm
Martin
Site Admin
Will do but what about my question about the effort to fit?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #867175 13th Nov 2020 8:48pm
Ninja man
Sorry, it appears to push in ok and not skewed but the button pushes in to turn on but when pushed to turn off doesn’t return out,but when I try the switch out of the dash it works fine so your suggestion that there are “lugs”or guides to remove makes sense just not sure what they are. Thanks for your help and patience,I’m a bit new to working on defenders.have ordered a genuine YUG000540LNF from John Craddock as I understand the bearmach part is a copy and not as good as LR oem part the colour is a better match on the dash as well( bit ocd)
Post #867190 13th Nov 2020 10:05pm
Martin
Site Admin
2015 D90 XS SW
Post #867273 14th Nov 2020 12:14pm
Ninja man
Thank you Martin that’s very helpfull Thumbs Up
Post #867275 14th Nov 2020 12:27pm
Ninja man
Hi,Martin lights are now working fine with switch.have fused the supply to light 40w led which by my calculation is 3.3 amp draw so 5amp fuse should be fine.i haven’t fused the switch live to operate the relay as it’s only low current and cig socket is fused already although it’s only used to charge phone or gps.does this all sound right as you seem very knowledgeable in these matters.
Post #867351 14th Nov 2020 4:55pm
Martin
Site Admin
I think you've used a bit of a hybrid of the heated seat switch YUF500150LNF and the spot light switch wiring. Shocked
Did you follow a diagram which came with the switch?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #867384 14th Nov 2020 6:06pm
Martin
Site Admin
See https://www.defender2.net/forum/post783400.html#783400  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #867390 14th Nov 2020 6:15pm
Ninja man
After looking at other relay wiring and switch wiring I realised the switch simply connects 1 (s/live)to 4 (out to relay 86),then 85 on relay goes to ground to complete the circuit activating the relay switch to connect battery live (fused) to 87( the light and 5 on the switch to illuminate the red “on” indicator). The 2 pin on the switch simply goes to the other backlight wires on the other dash switches. This enabled me to house the relay and fuse under the driver seat and just run two wires up to the dash(to connect pin 4 and 5) as the dash light (2) and s/live (1) were already there . So it’s essentially the same as other diagrams that just use the switch to complete the relay trigger circuit.
Post #867408 14th Nov 2020 7:47pm
Ninja man
If I’ve done something dangerous or I’ve missed something please let me know,your shocked emoji has got me doubting myself Sad there was no instructions or diagrams with the switch
Post #867422 14th Nov 2020 8:34pm
Ninja man
Checked out the thread you showed me and realised the switch simply connects the ground/ earth on the switching side of the relay so altered the wiring to reflect that, all works and is fused correctly 👍
Post #867524 15th Nov 2020 2:10pm
Martin
Site Admin
Great, I haven't worked it out but I think you may have had a problem with your old wiring where the dash illumination would have triggered your relay Laughing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #867548 15th Nov 2020 4:22pm
Ninja man
Thanks again for your help,much appreciated Thumbs Up
Post #867582 15th Nov 2020 7:27pm
