Home > Wheels & Tyres (L663) > Can you fit 18” wheels? Latest from Powerfuluk
Tim in Scotland
 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #867269 14th Nov 2020 12:47pm
DSL
At the risk of being slightly off topic, that’s this for?
Post #867276 14th Nov 2020 1:31pm
Tim in Scotland
I think that’s where they were trying to fit the Deployable ladder and made a mistake seeing if you could also fit the lunch box on the near side looking for the 3rd mounting position for the bolts into the trim below the window
One thing about his ideas with the wheel nuts and the stub cover - if you don’t use the OEM system I wonder what your insurer might think if you lost a wheel while driving........... would it be considered as a modification? Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #867278 14th Nov 2020 1:39pm
A proper ladder that's a lot less shonky than the one from JLR, a more generic frame that will allow a more useful range of products to be hung there, removable pannier...
Post #867279 14th Nov 2020 1:43pm
J77
The Black steels don’t do it for me personally.
Post #867352 14th Nov 2020 5:55pm
nikdim82
Greece
Can the Defender X have 18' wheels from factory? It seems they do not have it as an option and probably due to brakepads?
Post #869106 23rd Nov 2020 12:32pm
Watch the video by Doug Demuro, I'm sure only 20" is the smallest option due to the callipers.
Post #869131 23rd Nov 2020 3:07pm
J77
Not on Defender X. The P400 powered Defenders have bigger brake callipers.
Post #869146 23rd Nov 2020 4:06pm
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
19” is the smallest on P400/D300 they both have 4 piston callipers, 18” is the smallest on P300/D200/D250 they all come with twin piston callipers, 20” is the smallest on P400e comes with 6 piston callipers. Doesn’t matter if if is an X or not it all depends on the engine model. Also any Defender that is specified with 22” on the build will automatically get 6 piston callipers and that means smallest wheel you could change to is a 20”.
Post #869261 23rd Nov 2020 11:07pm
nikdim82
Greece
Thanks a lot guys! Seems that I need to choose maybe P300 to have the 18' wheels for larger profile for off-road tyres.
Post #869359 24th Nov 2020 3:54pm
