Home > Td5 > Power steering pump leak |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 933 |
First try snugging that up with a wrench 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
7th Oct 2020 1:14pm |
Greeny Member Since: 20 Mar 2018 Location: Buckinghamshire Posts: 272 |
Already tightened up what I could see, was all fairly tight to be honest. Instagram - @Land_Rover_Defender
7th Oct 2020 3:41pm |
Dunkrw1 Member Since: 09 Nov 2020 Location: North Devon Posts: 9 |
I had to replace mine looks line the same leek 😳
14th Nov 2020 6:50am |
Yes already thinking about replacing it. Tightening the bolts didn't work and neither did some stop leak.
So a new pump will be ordered! Instagram - @Land_Rover_Defender |
14th Nov 2020 8:48am |
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 81 |
There is an o-ring at the end of the metal feed pipe.
If this fails it lets fluid out via the threads. It’s hard to see on the photos but this could be the issue. Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
14th Nov 2020 8:59am |
Cheers,
It is really hard to tell where it is coming from, I have cleaned it multiple times and it returns wet all over the feed pipe, bolts etc. It is hard to trace it back to one spot. Making me think that replacing the pump is maybe best... Instagram - @Land_Rover_Defender |
14th Nov 2020 9:01am |
QYX100280
O Ring |
14th Nov 2020 9:04am |
Where does that O ring fit specifically? Instagram - @Land_Rover_Defender
14th Nov 2020 9:06am |
Click image to enlarge at the end of the pipe and also o ring on the hex part that`s trended in to pump badly But no part number for this o ring IF this hex part is re moved a spring loaded plunger will fly out you have been worn Last edited by dorsetsmith on 14th Nov 2020 10:04am. Edited 4 times in total |
14th Nov 2020 9:07am |
For the money I will give it a go!
Thanks for help! Hopefully that sorts it. Instagram - @Land_Rover_Defender |
14th Nov 2020 9:16am |
