Home > Puma (Tdci) > addressing a-not-so-great gearchange (MT82) |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3676 |
Does it get better as things warm up? Might point to an issue with the oil in the gearbox if so. If not then your probably on the right track with the linkage, lever etc.
11th Nov 2020 6:08am |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
Looks like you are covering most possible sources. However, I’d agree with Co1, that the first place to look is the oil. Check to see what comes out, and see if fresh oil improves matters. The Defender gearbox is a little notchy when cold (particularly 2nd gear).
I personally would apply all other measures before adding the slickshift. It will make the change feel more precise and mechanical, but will exentuate a bad gear change. This may confuse your findings somewhat. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
11th Nov 2020 7:38am |
Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 161 |
have a read of this;
https://www.defender2.net/forum/topic71984.html my gearbox went from perfect, to undriveable, back to perfect. All with two changes of oil... Mike |
11th Nov 2020 9:46am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
There are many "what-ifs" and I don't think you'll really know until you get the lever mechanism apart.
I found that lubricating the lever pivot, ball, and any moving parts made a huge difference (and I still believe that the gearshift on my '07 110 is the best and nicest Landrover gearshift I have ever driven that isn't on a Series I, far better than an R380). The bush upgrade didn't seem to have any particular effect. One factor I have never seen mentioned in any discussion of notchiness is the disappointing design of the selector shaft detent assemblies, especially on all but the earlies Defenders. These are well-known for the "stuck-in-gear" problem, but when you strip an MT82 you also realise that they never received any adequate lubrication when in service, and I suspect that in many cases it may be that they become very sticky, potentially causing a notchy shift and increasing the likelihood of the stuck-in-gear issue. Their cheapness of design and construction is one of the major disappointments, possibly the only one, of the otherwise good MT82 design, in my opinion. |
11th Nov 2020 10:58am |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
Thanks guys.
I'll work my way through. Re: the gearbox oil - I had this changed shortly after I bought it in summer. I can't remember if it made it better or worse (at the time I was distracted by the worn rear hubs) - then I would guess it was changed again or at least topped up when the output shaft was changed (not sure if that requires the oil to be changed), but I'll give it a good check too. |
11th Nov 2020 1:01pm |
Changing the output adaptor shaft requires the oil to be drained from the transfer box but not the gearbox. It is quite possible therefore that the MT82 oil was not changed.
11th Nov 2020 1:34pm |
Thanks Blackwolf.
So I bought it in July and had all the transmission oils changed at a local specialist in August. It was another garage that fitted the new output shaft in October. At least now I know that if there is an issue with the oil used that only one garage has been involved. |
11th Nov 2020 2:37pm |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 |
I have a 2010 USW and the only thing that pi————-s me off big time is the really bad gear select !! , I’ve even started thinking do I fit a superior box if there is one out there ?
Stew |
11th Nov 2020 6:27pm |
athelstan Member Since: 06 Aug 2019 Location: Kent Posts: 55 |
When I bought my 2015 XS from a non Land Rover dealer last year I noticed a very notchy gear change on the drive home. Despite being told that the car had had a full service and MOT I decided to take the car to my independent Land Rover specialist for another complete service. I told him about the notchy change and he said that the usual remedy for this was to completely drain the gearbox and replace with Lodexol FS 75w90 Synthetic oil. However the quantity of oil was crucial and had to be exactly 2.2 litres. Apparently there is no oil level plug and the oil has to be measured beforehand.
This has cured the notchiness and I am now one happy bunny. 2015 90 XS Station Wagon Puma 2.2 2015 Morgan Plus 4 |
12th Nov 2020 10:22am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8033 |
2.2 litres on an oil change, 2.4l on a new box fill. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
12th Nov 2020 2:09pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
I do not understand why the 2nd gear is not directly below the 1st. Going 1st to 2nd, gear lever has to go a bit more to the left. And Seems it is not just mine. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
12th Nov 2020 3:04pm |
^^ Not the case on mine, 1-2, 3-4, and 5-6 are all aligned. Perhaps your housing needs adjusting.
12th Nov 2020 3:39pm |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
Mine also has no issues with gears being aligned Roaming around 🇳🇴🇨ðŸ‡
12th Nov 2020 4:02pm |
I've use two "specialists" up here in Aberdeenshire and both put the wrong oil in, and both over filled it. I tried to correc them on the fact the MT82 has no filler plug and both gave me the "listen pal, we've been doing this for years blah blah" trust no-one, buy the correct oil yourself and put 2.2ltrs in, no more. then see how you get on. Mike |
12th Nov 2020 7:13pm |
