Home > Technical > Bigger Wheels - Speedo?
robrennie
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Hi All,
I am putting bigger wheels on my 07 Puma Defender - I am guessing that i will need to make some changes somewhere to adjust the speedo?
Any thoughts?
Post #866137 8th Nov 2020 7:03pm
dorsetsmith
https://www.land-rover-blog.co.uk/how-to-r...and-rover/ you find this rear of the transfer box under the green transponder and it can be a plan to remove
or https://www.ashcroft-transmissions.co.uk/s...-c102.html
Post #866141 8th Nov 2020 7:10pm
robrennie
Thank you Sir!
Post #866142 8th Nov 2020 7:12pm
camelman
How big you going?
The speedo already over reads on the standard tyres. If you go to 33 inch tyres (285/75/16 or 255/85/16 equiv) it will read almost bang on.
If you go taller than that, it will underread.
Post #866157 8th Nov 2020 8:21pm
Organised Chaos
United Kingdom 2008 Defender 130 Puma 2.4 HCPU Cairns Blue
Some where in the back of my mind, you can program the tyre size into the instrument pack using the nanocom, did this along time ago when i went from 750 tyres to 235 tyres, it also then gave me the option to up the speed limiter from 82mph to 90 mph but left it at 82.
Post #866159 8th Nov 2020 8:40pm
robrennie
Thanks for that - I did wonder if it was programmable.
I am getting the wheels sorted then off to Ashcroft Transmissions for an auto box to be fitted - if it is a reprogramming job, then might be something they can do.
Cheers,
Post #866165 8th Nov 2020 9:03pm
camelman
Ashcroft supply a speedo correction kit for the puma for £75
Post #866170 8th Nov 2020 9:31pm
robrennie
So they do!! - thanks for that Very Happy
Post #866172 8th Nov 2020 9:35pm
