Home > Technical > Bigger Wheels - Speedo? |
https://www.land-rover-blog.co.uk/how-to-r...and-rover/ you find this rear of the transfer box under the green transponder and it can be a plan to remove
or https://www.ashcroft-transmissions.co.uk/s...-c102.html Last edited by dorsetsmith on 8th Nov 2020 7:17pm. Edited 1 time in total |
8th Nov 2020 7:10pm |
robrennie Member Since: 20 Mar 2018 Location: Somerset Posts: 28 |
Thank you Sir!
8th Nov 2020 7:12pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3368 |
How big you going?
The speedo already over reads on the standard tyres. If you go to 33 inch tyres (285/75/16 or 255/85/16 equiv) it will read almost bang on. If you go taller than that, it will underread. |
8th Nov 2020 8:21pm |
Organised Chaos Member Since: 20 Dec 2008 Location: Chesterfield Posts: 56 |
Some where in the back of my mind, you can program the tyre size into the instrument pack using the nanocom, did this along time ago when i went from 750 tyres to 235 tyres, it also then gave me the option to up the speed limiter from 82mph to 90 mph but left it at 82.
8th Nov 2020 8:40pm |
Thanks for that - I did wonder if it was programmable.
I am getting the wheels sorted then off to Ashcroft Transmissions for an auto box to be fitted - if it is a reprogramming job, then might be something they can do. Cheers, |
8th Nov 2020 9:03pm |
Ashcroft supply a speedo correction kit for the puma for £75
8th Nov 2020 9:31pm |
So they do!! - thanks for that
8th Nov 2020 9:35pm |
