![]() | Home > Td5 > Defender heated seats timing |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2278 ![]() ![]() ![]() |
Theres a little thermostatic switch on the element that switches the heat pads off when the temperature is reached.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
90GTR Member Since: 05 May 2020 Location: London Posts: 201 ![]() ![]() ![]() |
Thank you.
Can this be adjusted at all? Is it easy to get to if so? |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 959 ![]() ![]() ![]() |
No adjustment is possible unless you replace the thermistor with a higher temp setting. If you pull back the seat cover you will see it within the grid. I suppose you could remove the thermistor but you run the risk of overheating. Removing it means you control when it is on or off. If you do that and leave your truck running you risk a fire. I replaced mine with carbon fibre seat elements and they are either on, high, low or off. You control it.
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
