Home > Td5 > Defender heated seats timing
90GTR
2016 Defender 90 V8 Petrol Works V8 Auto Santorini Black
Just had some Defender LR puma heated seats fitted to a TD5 and used a retrofitted ebay wiring kit with ignsense (genuine LR TD5 buttons).
I'm finding once the button is on, the seats heat up for approx 5-10mins and then the heating seems to turn off (button still pushed in / led light remains on). If the vehicle is switched off and on again, then the heater will turn back on again.
I was under the impression the heat was continuous if switched on?
Any ideas or should I just get them to look at the wiring again?
Post #865357 4th Nov 2020 12:13pm
Mo Murphy
Theres a little thermostatic switch on the element that switches the heat pads off when the temperature is reached.
HTH
50 Shades of Pennine Grey
Post #865379 4th Nov 2020 3:16pm
90GTR
Thank you.
Can this be adjusted at all? Is it easy to get to if so?
Post #865385 4th Nov 2020 3:37pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
No adjustment is possible unless you replace the thermistor with a higher temp setting. If you pull back the seat cover you will see it within the grid. I suppose you could remove the thermistor but you run the risk of overheating. Removing it means you control when it is on or off. If you do that and leave your truck running you risk a fire. I replaced mine with carbon fibre seat elements and they are either on, high, low or off. You control it. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #865562 5th Nov 2020 3:18pm
