Home > Maintenance & Modifications > Battery charger recommendations
Page 2 of 3 <123>
excossack
and other CTek user here. Via Halfords with a trade card. Smile 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #865558 5th Nov 2020 2:47pm
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
You wait until you have a big battery to charge (the one instead of your engine) Shocked
Post #865598 5th Nov 2020 7:08pm
excossack
In what way.? 1999 Defender TD5 110
Regards
John M0VAZ
Post #865604 5th Nov 2020 7:28pm
Adammacky
Ctek user here too! Kept the 110 on trickle charge for ages through covid19 and can't fault it.
Post #865606 5th Nov 2020 7:45pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Have a Dometic IU1012 installed in the seat base and a ip67 connector on the rear cross member to be able to charge the car without too much hassle. Don’t use the car as much as I used to.
Post #865665 6th Nov 2020 7:15am
seriesonenut
I also have a connection point hooked up full time
12v3 by Richard Holmes, on Flickr 2010 XS USW
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #865754 6th Nov 2020 5:43pm
roel
I have also a Ctek something with 25 Very Happy I bought it in 2008 and it is still working fine. Roel
2003 90 Td5 (2009-now)
Post #865797 6th Nov 2020 9:31pm
spudfan
Ireland
None of us are Big Cry 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #865811 7th Nov 2020 1:12am
northernerindevon
United Kingdom 1986 Defender 90 300 Tdi HT Nato Green
Another CTEK user here.
Mine gets left on for weeks or months at a time when I am away with work. Fit & forget.
I see they sponsor Harrys Garage too. Good enough for Harry, good enough for me...
Post #865818 7th Nov 2020 6:56am
Pat
Wales
Amazon have good prices on the CTEKS at the moment. It started with a kiss, never thought it would come to this.
SIII CSW Safari, limestone, (JAC 914N). Where is she now?
It's not a car, it's a way of life!
Post #865853 7th Nov 2020 9:47am
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
I am now torn whether to give a cheaper option a go or spend more for one of these ctek ones, they seem to be well regarded by many on here...
I do tend to believe in buy quality that lasts but a cheaper one may be fine anyway!
Post #865860 7th Nov 2020 10:44am
seriesonenut
I think the Ctek is worth the money, as said it re sets after it has been disconnected and also has the added advantage of a recon mode which normally fixes most battery issues. The other advantage is it fits inside a B&Q waterproof box so it's waterproof if need be, you can see it in the orange tube (less than £5)
dinitro2 by Richard Holmes, on Flickr 2010 XS USW
Post #865876 7th Nov 2020 12:00pm
Bluest
I’m pretty sure Cteks are IP65 anyway, so ok as as you don’t immerse them. 2007 110 TDCi Station Wagon XS
Post #865879 7th Nov 2020 12:19pm
seriesonenut
ah I did not know that. I went all belt and braces anyway given it sat like that for weeks during lockdown 1. 2010 XS USW
Post #865881 7th Nov 2020 12:27pm
Whilst CTEKs are reliable ~ one of mine has been permanently plugged into a vehicle for over 8 years; I did have an issue with another unit when the mode button would not cycle through the options. The warranty replacement process direct with CTEK was very organised and I had a replacement unit within a relatively short period of time.
Post #865884 7th Nov 2020 12:43pm
Page 2 of 3 <123>
