![]() | Home > Technical > Gearbox rebuild number? |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 867 ![]() ![]() ![]() |
Does anyone recognise the number stamped above the serial no. In this photo?
![]() Click image to enlarge I presume it is a rebuild number but would be interested to know when/where if it was rebuilt if anyone can help. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
London 52 Member Since: 21 Oct 2014 Location: Lincoln Posts: 312 ![]() ![]() ![]() |
Might be worth sending a photo of the number to Ashcroft Transmissions, I sent a copy of the number on my transfer box and it turned out it was one of their rebuilds.
Don |
Thanks both, I'll drop Dave a line and see if he can help, it might give me an indication as to whether I'll need a set of rings etc. 1985 127 V8 Build Thread
Mr Ashcroft has confirmed it had a normal rebuild in April 2011.
From initial inspection it looks as though the selector bush disintegrated and the box was removed (large lumps of selector bush as opposed to ground up bits). 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
