Home > Technical > Gearbox rebuild number?
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Does anyone recognise the number stamped above the serial no. In this photo?
I presume it is a rebuild number but would be interested to know when/where if it was rebuilt if anyone can help. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #865348 4th Nov 2020 10:02am
London 52
United Kingdom 2005 Defender 90 Td5 CSW Belize Green
Might be worth sending a photo of the number to Ashcroft Transmissions, I sent a copy of the number on my transfer box and it turned out it was one of their rebuilds.
Don
Post #865462 4th Nov 2020 10:14pm
northernerindevon
United Kingdom 1986 Defender 90 300 Tdi HT Nato Green
I'd second that, I had a rebuild stumpy R380 fitted last year from Ashcrofts and the format is similar; 1 letter and 5 digits.
Got to be worth an ask.
Provide them with as much detail as you can and I'd have thought they'd be able to assist, if it is one of theirs.
Cheers, Paul
Post #865490 5th Nov 2020 7:52am
Shroppy
Thanks both, I'll drop Dave a line and see if he can help, it might give me an indication as to whether I'll need a set of rings etc. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #865498 5th Nov 2020 8:46am
Shroppy
Mr Ashcroft has confirmed it had a normal rebuild in April 2011.
From initial inspection it looks as though the selector bush disintegrated and the box was removed (large lumps of selector bush as opposed to ground up bits). 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #865512 5th Nov 2020 10:05am
