Home > Puma (Tdci) > Air Con (Or lack of it!!!)
Page 2 of 2 <12
Zagato
Dave-H wrote:
Also, after the service it seemed a hell of a lot smoother, would it have had the ECU altered?
If under warranty they would of updated the ecu software to latest spec [which is a lot better] so yes probably does drive better Very Happy
So earlier models drive differently to later one's! Do you know what the ECU update entailed, when did they they change it?
Post #86525 29th Aug 2011 2:00pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
My air con works fine ...
In the winter only use the heater .. But here in the summer is Hot!
These hollidays used it a lot (over 40º outside) and after 2/3 minutes you could allready feel the cool inside all around ... Worked fine on my 40 /50 km trip every day during hollidays!
My right shoulder started to get frozen after 20 min because the rectangular central vents are always open and you cant direct them ... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #86527 29th Aug 2011 2:11pm
nivmargalit
Israel 2007 Defender 110 Puma 2.4 SW Stornoway Grey
my aircon work fine , but after 40 minutes , steams start to going out from the hols and it stop coolling.
This hapand only when the front aircon is on, if I open the rear aircon as well the steams not show up.
any see this?
Post #108798 20th Dec 2011 7:49pm
Page 2 of 2 <12
