Home > Puma (Tdci) > Air Con (Or lack of it!!!) |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
My air con works fine ...
In the winter only use the heater .. But here in the summer is Hot! These hollidays used it a lot (over 40º outside) and after 2/3 minutes you could allready feel the cool inside all around ... Worked fine on my 40 /50 km trip every day during hollidays! My right shoulder started to get frozen after 20 min because the rectangular central vents are always open and you cant direct them ... Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
29th Aug 2011 2:11pm |
nivmargalit Member Since: 19 Apr 2011 Location: under the sun Posts: 30 |
my aircon work fine , but after 40 minutes , steams start to going out from the hols and it stop coolling.
This hapand only when the front aircon is on, if I open the rear aircon as well the steams not show up. any see this? |
20th Dec 2011 7:49pm |
