![]() | Home > Maintenance & Modifications > BAS 170 map |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
After having experienced such success with the Extreme 4x4 ARB´s, I fitted to my 90 last weekend, I found myself musing that the chassis now behaved so well it could do with a couple more horsepower to chew on.
https://www.defender2.net/forum/topic75137.html On Wednesday evening I sent off my order to BAS, and by Friday midday the remap remote unit had arrived. A few hours later I had flashed the ECU and went for a test run. Exactly as described in various posts on here, the improvement is immediately apparent and is as impressive as I´d hoped. A graceful and silky smooth early throttle response through the first 2/3 rd´s of the pedal, is followed by an strong surge of power toward the end. Feels like a far more lively vehicle than beforehand, whilst being more pleasent in traffic. A run up the autobahn confirmed that the speed limiter now allowed greater velocities than I´ve seen in a Defender previously. I went briefly up to 161 kmh (on my GPS), lifted my foot and grinned, satisfied that that was quite enough! ![]() My 90 stands high, exposing even more of the 285 section tyres than most. Add to that the visor, and it aerodynamically similar to the proverbial barn door! The amount of wind noise that a Defender generates at that speed made it clear to me why Defneders don´t generally nee d to go even faster. I´m very happy with the whole package, and my desire to climb into the Defender at every opportunity is strengthened! Peter, thanks very much. ![]() ![]() ![]() ![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT�s, Recaro CS�s, anorak, wellingtons Last edited by Wild Card 90 on 7th Nov 2020 6:24am. Edited 1 time in total |
Darcy Fairfax Member Since: 06 Oct 2014 Location: London Posts: 721 ![]() ![]() ![]() |
Still to do this mod, sounds thoroughly worth it.
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
It is!
doncarloz Member Since: 29 Oct 2017 Location: Styria Posts: 60 ![]() ![]() ![]() |
Are you running a bigger intercooler and/or an egt-gauge?
I switched to the BAS 170 stage aswell and might install the bigger IC for peace of mind. I´m not sure about the egt-monitor though. ___________________________________ 1993 D1 200 Tdi 2015 110 DCPU 2.2 Tdci 2017 RRS 3.0 TDV6 |
Thanks for the info
![]() 1993 D1 200 Tdi 2015 110 DCPU 2.2 Tdci 2017 RRS 3.0 TDV6 |
I have an Ultrascan gauge running off the OBD II directly in front of me on the column.
![]() The latter three give me a clear picture of whats going on. I see immediately when the dpf goes into regen, as the cat temps shoots up to 550°. The slight variations in water temperature, most significant when towing uphill in the summer heat are also immediately monitored. 90 - 93° is the normal temp. Hot outside, hill and trailer combined can push the water temperature up to 105°. No problem, and the factory gauge still shows a horizontal healthy 90. Interestingly, there was a noticeable increase in cat temperature when I gunned it for a few minutes on the autobahn. I actually briefly saw 630°, but it very quckly dropped once i backed off. water temperature stayed at 93° the whole time. Yes, ![]() I´ll swap to fresh silicone hoses at the same time. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT�s, Recaro CS�s, anorak, wellingtons Last edited by Wild Card 90 on 4th Nov 2020 6:24am. Edited 3 times in total |
Thanks for the insight. It never stops with those bloody defenders😁 ___________________________________
Still pleased by the 170 BAS remap, but the the problem is I´ve started to get used to the smoother pickup and the extra power, and have somewhat forgotten how it ran beforehand.
So when my son recently borrowed my Defender (and as he drives a number of fast cars daily) I wondered if he would notice or comment on the difference. He was grinning widely when he handed me back the keys, and quipped that in the lower gears it is almost sportscar like in its pull and willingness to wind up the revs. He was well impressed! ![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT�s, Recaro CS�s, anorak, wellingtons |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
Good to hear!!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
