Home > Puma (Tdci) > Under seat wiring loom |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1082 |
Is it orange instead of yellow, maybe? Could be C2004/C2005 connecting the rear doors (blue/purple door switches, others central locking motors).
Click image to enlarge |
1st Nov 2020 8:45pm |
Ninja man Member Since: 01 Feb 2020 Location: South Posts: 36 |
Thanks for the reply, does that mean one of them could be live when ignition is on to allow a feed to a switch and then a relay to power a work light?
1st Nov 2020 10:00pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6613 |
Nope - none of those is an ignition feed.
If you have a 90 it's unused, it's the connector for the second row doors - central locking motors and door switches. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
2nd Nov 2020 10:12am |
who about purple wire that go drivers side rear 20 amp fuse not switch by ignition ? |
2nd Nov 2020 11:57am |
Sadly the purple wire is not present on mine as it’s 2014 and they apparently stopped putting it in 2013 , I am sure there must be something under the seat that is switched after ignition if not I’ll have to take one off of a wire behind the dash as I’ve got to fit a switch there anyway but thanks for your help all of you. I only wanted a work light that switches on at the dash via a relay under seat but it’s proving to be a right ball ache to do it properly
2nd Nov 2020 7:05pm |
If it’s unused does that mean it’s not connected either end or could I fit a relay in the appropriate place and instead of powering windows power a light ? Probably grabbing at straws but electrics in defenders never seem logical or it’s possibly just me |
2nd Nov 2020 7:13pm |
It's unused as you don't have the second row of doors. It's connected to the alarm ECU at the other ends of the wires 1988 90 Td5 NAS soft top
2015 D90 XS SW |
2nd Nov 2020 7:20pm |
Ok that’s fine I’ll stick to plan A and delve in behind dash, thanks for your help ,much appreciated
2nd Nov 2020 7:24pm |
