![]() | Home > Modifications & Maintenance (L663) > Anyone got a winch fitted? |
Is there a second battery? I dont know of any other LR vehicles that have a second battery when LR supply a winch kit. 130's have feeling's as well you know
Dave B Member Since: 28 Oct 2020 Location: Midlands Posts: 7 ![]() ![]() |
I dont know TBH. I thought an auxiliary battery was a prerequisite with an electric winch? Hopefully someone will have the answer. We need to fit an auxiliary battery for overland preparation.
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2688 ![]() ![]() |
No second battery, it seems the cables hook up to the power/ground points in the engine bay.
No its not essential, its good practice but not THE LAW
Thank you. We will investigate further then. We dont want to strip the car down if someone has the answer. All other Land Rovers/Range Rovers I have owned have had a designated place for a second battery. |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
PowerfulUK will be doing an install video shortly having been gifted a winch by LR, might be useful. James
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Also the installing instructions are on the Accessories Installing Website if you want to look it up
Here for the mounting base http://accessories-instructions.landrover....r/G2409788 And the actual winch installation is here http://accessories-instructions.landrover....r/G2414506 No connections to a 2nd battery are shown Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Thanks. That’s useful anyway. Ive searched there and it’s brings nothing up for second battery. Looks like we will have to get our thinking caps on if we want a fridge.
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
Check out this guy on Instagram he’s just put a decent fridge setup in his 110 he runs the defender modifications page on Insta
https://www.instagram.com/p/CGdbo5wM7dQ/?igshid=s8ujt1znkqhv |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 ![]() ![]() |
i have a warn winch fitted to my RRS, there was no need for a second battery yet another pommie bar steward down under
MY20 110 P400 SE Defender MY10 3.0 RR Sport |
Q86ARR Member Since: 28 Feb 2017 Location: Earth Posts: 38 ![]() |
No secondary battery on Defender
Current JLR vehicles use a VQM (voltage quality module) now for stop / start operation. The winch connects to the terminals under the bonnet I’ve got to fit in the near future Land Rover list the winch at just over £3k, but that doesn’t include the winch fitting kit |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17563 ![]() ![]() ![]() |
Like AndrewS has said, no standard Landrover winch kit has ever provided a second battery and the new one is no different.
Spikemd Member Since: 01 Nov 2020 Location: Sacramento Posts: 2 ![]() ![]() ![]() |
You want your winch connected to the main battery, not the secondary. Whenever u use the winch, it takes a lot of amps so always have your engine running. It would draw down a secondary too quickly.
Secondary batteries are used for ancillary items like fridges, lights, chargers and such usually when the truck isn't running. Good idea to have an isatpr or better a dc to dc charger and fuse box for each additional circuit. Use a deep cycle battery bit can only draw down a lead acid 50% before you start hurting the battery. Lithium now can be drawn down 90% weight 1/3 of the weight and charge faster. Downside is cost, but we have seen amazing performance from a 120ah lithium. |
agvartanian Member Since: 14 Aug 2020 Location: California Posts: 1 ![]() ![]() |
I got my winch and front A-frame fitted about 2-weeks ago. No secondary battery, connection is straight to the primary as shown in the installation instructions.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Last edited by agvartanian on 1st Nov 2020 5:48am. Edited 2 times in total |
