Home > Maintenance & Modifications > Receiver Hitch Choices
Page 2 of 2 <12
You'll need a spacer to clear those bolt heads, unfortunately. This picture is of Blackwolfs NATO hitch on his receiver hitch chassis plate and shows the spacer he made from 15mm steel plate:
 Darren
Post #863936 27th Oct 2020 10:51pm
Andy RV
Thanks Darren, I thought you’d have the answer! At least it’s a simple fix.
Post #863971 28th Oct 2020 7:52am
Marky5522
United Kingdom 2015 Defender 110 Puma 2.2 XS DCPU Corris Grey
I just received my Safari Eqip receiver today and have similar thinking to you. There might be enough room if the bottom 2 bolts were swapped to suitable cap heads but the Nato hitch rotation lock pawl still fowls the receiver section if you need it in the unlock position.
Post #864089 28th Oct 2020 8:21pm
^^ Not a problem if you space it in the way I have. You just have to be a bit imaginative with the pin.
Post #864103 28th Oct 2020 9:36pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Is it just me that thinks that the type approval system is a load of bullocks, if you are not allowed to tow with something like a Terrafirma receiver hitch which is securely bolted on and the hitch held in with a big pin, while you are allowed to tow 3.5 tonnes with the factory Discovery 3/4 hitch which is infamous for falling off in the road with no provocation even without a trailer attached.....?
Fortunately not blighted with such nonsense regs here, but it seems crazy. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #864549 31st Oct 2020 11:16am
Generally speaking, these sorts of regs keep us all safe. They do have a habit of falling down when applied to relatively odd vehicles like Defenders, though. The fact that the rules about tow bars either does or doesn't apply to physically identical Defenders depending on when they were registered is clearly nonsense, but I guess it's a trade off between that and much more complex regulations. Darren
Post #864627 31st Oct 2020 7:48pm
BogMonster
Except that they clearly don't as the failings of the factory system are well known, and presumably somebody passed that for type approval. It needs to be a man with common sense who can look at something and say that is safe or that is not safe. I understand the purpose of it, just the implementation is flawed if it lets defective products through and bans the use of perfectly good ones. ---
Post #864658 31st Oct 2020 9:50pm
Iggle piggle
United Kingdom 1989 Defender 90 V8 Petrol ST Alpine White
I have recently taken delivery of a new Ranger Raptor that surprised me by having a 2” receiver hitch as standard,
I haven’t towed with it yet & I know it’s tried & tested but the thought of relying on that pin & R clip is concerning me a little 😳
Post #864669 31st Oct 2020 10:28pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
It’s surely no different to a single pin on a Dixon bate sliding drop plate though? Albeit a slightly narrower pin.
Post #864673 31st Oct 2020 10:52pm
Iggle piggle
Yes probably but I’ve never had to rely on one of those either, Rolling with laughter
Like I say it’s tried & tested around the world but the thought of our 2t wobble box only held on with a pin the thickness of my finger is worrying Shocked
Post #864680 31st Oct 2020 11:18pm
Look up the strength of the pin. You'll be surprised.
Post #864691 1st Nov 2020 12:31am
Page 2 of 2 <12
