Home > Maintenance & Modifications > Time required to fit a Webasto?
Fellrunner
 2015 Defender 110 Puma 2.2 SW Corris Grey
Hi All
Having prevaricated about getting a heater fitted for some years now, I’ve finally got round to doing something about it. Have had various mods previously done by Twisted, I thought I’d go to them. I know they’re expensive, but ...
Anyhow, I’ve just received a quote, which includes 30 hours to fit a Webasto underneath the cubby box within a Mud Heat Locker and the digital controller fitted into the dash.
30 hours, or 4 days, seems like a lot of time. But, to be fair, I’m certainly no expert. So I thought I’d check here. For those that know what this involves, is this about right, give or take?
Many thanks
Post #864449 30th Oct 2020 5:26pm
LR90XS2011
was with Ian from IRB at the weekend he was fitting a Webasto under the bonnet in a space under the rear of the left hand wing may be worth a chat with him DEFENDER 90 TDCI XS,
Post #864461 30th Oct 2020 6:25pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
Assuming you are meaning space heater as opposed to pre heater? Fitted my eberspacher in the rear with the dip pipe diesel feed in half a day.
Very good they are too. Nice and toasty. Easy to do so give it a go yourself.
Post #864463 30th Oct 2020 6:42pm
Mdm
any truck/lorry camper van place will fit them and correctly in 1-2 days depending on location inside a defender.
we spent a day on mine as i wanted to run the exhaust pipe to the rear via a silencer.
buy the basic model and if you want to upgrade to better controller and remote \ app control you can do at a later date.
2kw is plenty for a 90/110 as well.
they dont use much fuel and are fairly good on battery use as well
Post #864468 30th Oct 2020 7:00pm
jst
My coolant preheated, thermo top c, is also i under the engine close to bulkhead on passenger side. My air heater is under the 2nd row seats.
I dropped fuel tank and fitted two pickups, routed each line along chassis to heater location with in line pumps. That took me a morning, 8 to 1300. 5hrs
Next day 0800 to 1600 thermo top fitted under wing and plumbed in. 8hrs
Then approx 2hrs to then connect up wiring and fit control box to dash.
So 15hrs for thermo top. Bit less for air heater as no coolant hoses to sort. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #864483 30th Oct 2020 8:19pm
Fellrunner
Thanks for your replies.
Apologies, I should have mentioned it’s the air heater being mounted inside the cabin.
It sounds like, if I add in time to remove the dash and fit the digital controller, it’s not getting as ridiculous as I first wondered, albeit it’s at the top end of what the time requirement may be.
Post #864536 31st Oct 2020 9:43am
jst
12hrs for an air top assuming they are dropping the tank. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #864682 31st Oct 2020 11:25pm
camelman
Took me about 3 hrs to fit my Airtop (well chinese equivalent) in the 130. I have a seperate tank however so I can run it on red diesel.
Post #864707 1st Nov 2020 9:06am
isacs
I fitted a planar d2 with the under cubby kit supplied by Brendon @ 4x4overlander in a day.
Post #864755 1st Nov 2020 12:57pm
