![]() | Home > Off Topic > 3D printer recommendations |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3797 ![]() ![]() |
Hello
I don't have one but have bought some for work, years ago we started with the Makerbots. now we have a selection including resin ones. For home use a lot of the techs at work use the Eder range, the Ender 3 pro and Ender 5 some have upgraded to a heated glass bed. Well in your budget and from what I have seen they have printed out some good quality items. https://www.creality3dofficial.com/product...rQQAvD_BwE This device is probably actually better than the first maker bots we bought that were over £2k when they came out... I currently have a project requiring another 3D printer for work and one of our suppliers I asked what would he recommend for a home printer around £400 as I'm keen for looking at one, When they come back I will update you ![]() |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1233 ![]() ![]() ![]() |
Just be wary of this. A friend of mine found a large 3D printer (half a metre in all dimensions) for about £500. So far I've managed to dissuade him from going with it because it wasn't enclosed. On printing a part that big the main issue is going to be managing the heat and preventing the part from deforming as it cools. An enclosed build area that can control this I feel is a must on something that size. At my previous job we had an old (one of the first commercial ones but still not cheap at circa £0.5m when they bought it) 3D printer that had quite a small build volume but the mechanical guys used to knock out much larger prints very regularly by slicing the model into smaller bits before printing the individual parts. They were then clipped / glued / doweled / bolted back together depending on the application. With 3D printing you have the benefit of not just doing a straight slice of a part but making a jagged edge so that it offers a greater surface area to bind over. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 719 ![]() ![]() ![]() |
Thanks for the input chaps, like the look of the ender v5 Stacey I’ll have to do a bit of research on that one.
Sako, I understand what your saying, what volume would reckon would avoid that issue? I was looking at about max 300mm width and length, not too worried about mega height and the things I want to print will probably be no higher than a couple of inches. |
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 238 ![]() ![]() |
I have a Ender 5 Pro... for the money the prints are superb!
I have printed a name tag and coat hook for my daughter today: ![]() Click image to enlarge ![]() Click image to enlarge |
chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 412 ![]() ![]() ![]() |
Prusa would be my recommendation and you can build a very nice enclosure for it from their plans with a £8 ikea table.
I started with a Robo 3D which is great and up for sale if you wanted something to start off with as I am now printing with multi filaments. TC |
Ecco Member Since: 31 Oct 2015 Location: Kuala Lumpur Posts: 280 ![]() ![]() ![]() |
..im recommending you to use Ultimaker Cura to generate gcode files for your printer..It does support huge variety of printers and its fantastic tool, perfectly working with 3dsmax (im using it as well). Just export 3dsmax->STL->open STL by Ultimaker Cura, and simply do slicing and save your file for 3d printing. Trully fantastic tool, im sure you will love it. Its free.
Excellent thanks guys, this has given me plenty to go at.
..and hint before you export STL file from 3dsmax..make sure you select all parts of object you want to export and collapse it in to single mesh..and then, convert it to EDITABLE POLY. Then just export. Without doing this, i did noticed some weird triangulation during slicing (max is not cad tool which is why it generates plenty of triangulation).
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
I am looking at getting a 3d printer in the near future. I am looking at a prusa. For the build yourself kit it's about £700.
I borrowed one a few months ago and it worked well. The prusa have a good online community for those willing to tinker. You can also get the mini which is a good price I think if you are looking at a large volume you are looking at expensive or poor quality - which means lots of frustration and a possibility of an expensive ornament. Also the printing can be slower due to the mass of the kit that has to constantly change direction. I hope you make a good choice and it works well for you. I also look forward to seeing your creations. Best of luck. Mick |
