Home > Maintenance & Modifications > Dye TD4 headliner black
felixp
Germany
Has anyone attempted or even managed to do this properly?
I am currently in the middle of finding and sealing a leak in my roof and while the headlining is out I got the idea of making it black. I don't have the skills/time to remove the old material and cover it in something like suede and got the idea of dying it black.
I've seen some videos on YouTube and it looked really good! I am just wondering if the material used by LR is even able to be dyed correctly?
Has anyone tried this before or knows which material the original white headlining is made of?
Any ideas and opinions are welcome! Thumbs Up
Greetings from Munich!
Felix
Post #864161 29th Oct 2020 9:17am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
That video might help. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #864163 29th Oct 2020 9:28am
felixp
Germany
Thanks, looks great - but I don't really want to use new material/strip the old.
Thinking if a paint roller and some textile dye is an easier way to go as what I have seen on Youtube looks really good!
Some even use normal spray bottles to apply the dye... ?t=204
However I am not sure of the material used in our LRs is able to absorb the dye correctly as the headlining I am used too from other cars is far softer than that in my LR. It seems rather plastic. Would be interesting to know if the headliner of the Freelander seen in the video is the same as in my Defender...
Post #864165 29th Oct 2020 9:34am
o4dn
FWIW, many people (myself included) strip and paint the head liner on Disco 2 to fix the sagging that inevitably happen, I reckon it should be easier on a Defender considering there is no fabric to start with… “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #864168 29th Oct 2020 9:45am
hank
I recently bought a few cans of TRG Black Vinyl Dye to do just this! But haven’t got round to it yet as I don’t have access to my parents garage due to lockdown.
I figured if it goes horribly wrong I can always retrim it. > 110 XS Double Cab
Post #864171 29th Oct 2020 9:50am
CarMan
Would the TRG Black Vinyl Dye also be the go to product for sun-visors? Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #864179 29th Oct 2020 10:13am
felixp
Germany
I thought the same.. start with the rear piece and if things go really wrong there is always an Plan B...
From what I remember, the material looks the same on the sun visors.
Post #864180 29th Oct 2020 10:15am
hank
Yes same product Thumbs Up
I thought I would try a trial piece with a small trim piece from my double cab to see how it comes out (don't think station wagon's have these trims though)
That youtube video is good. Can't quite tell, is the freelander headliner kind of furry? The Defender is flat plastic/vinyl > 110 XS Double Cab
Post #864190 29th Oct 2020 10:35am
felixp
Germany
The Freelander does seem to have a softer textil than the Defender material below Whistle
Post #864224 29th Oct 2020 1:23pm
camelman
Not sure if it will work on the vinyl but I just spray painted my lasalle headlining black and its holding up well.
Post #864231 29th Oct 2020 1:58pm
felixp
Germany
Looks great!!
Post #864238 29th Oct 2020 2:33pm
hank
Finally finished dying my headliner... Used six cans I think!
Some progress pics
 > 110 XS Double Cab
Post #870579 30th Nov 2020 7:46pm
V8Simon
United Kingdom 1985 Defender 90 V8 Petrol SW Auto Arles Blue
[quote="camelman"]Not sure if it will work on the vinyl but I just spray painted my lasalle headlining black and its holding up well.
Looks really good, I've a Lasalle one waiting to be fitted, what colour/texture was it to start with, I think I went for the basic grey? 1984 90 V8 puma want to be.
Post #870746 1st Dec 2020 3:32pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Nice Smile 6 of the 400ml cans?
Is this the best source? https://www.vinyldye.co.uk/Black-Vinyl-Dye-Plastic-Paint-By-TRG
Post #870773 1st Dec 2020 6:37pm
hank
Yes the large 400ml cans. That site is indeed the correct product but at £15.99 per can.
If you order from the below ebay link the guy does them for £10.16 per can when you buy 4+. Quick delivery too
https://www.ebay.co.uk/itm/283832974379
But that vinyldye website does have some excellent instructions https://www.vinyldye.co.uk/How-To-Use-Vinyl-Spray-Dye
Couple of tips, don't use acetone as suggested - this melts the vinyl (ask me how I know Laughing ) so just clean up well with detergent and water... Or try the TRG cleaner they suggest
Secondly... Many many fine coats gives a much better finish than going with fewer thick coats. At first you will think it's not covering but stick with it and build up the coats. It dries in minutes with thick coats so doesn't take too long. Just keep going panel to panel doing a thin dusting and by the first panel will be dry by the time you finish the last one so you can can just go round again and again and again until you're happy > 110 XS Double Cab
Post #870791 1st Dec 2020 8:08pm
