![]() | Home > Technical > Td5 110 Fuel Filler Pipe Part No. |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
I keep going around in circles trying to work out the correct part number for the rubber filler hose for my prefix 2A Td5 110.
The closest I have got seems to be WLH500070 but it is listed for 5A prefix onwards and i have some vague recollection about the filler necks being a different size on later models. Could anyone possible confirm please? Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6645 ![]() ![]() ![]() |
This is the info for the 90 where the tank inlet definitely changed size
https://www.defender2.net/forum/topic74328.html 110 info below: 110 non Hi-Cap and 130 PIPES 1. ESR4414 (XA159807 to 5A690323) - start of Td5 to mid 2005MY [superceded to WLH500070] 2. WLH500070 (5A690324 onwards) - mid 2005MY Td5 on and all Pumas So basically 1 pipe. WLH500070 110 Hi-Cap PIPES 1. WFH101710 (XA159807 to 5A690323) - start of Td5 to mid 2005MY [superceded to WLH500050] 2. WLH500050 (5A690324 onwards) - mid 2005MY Td5 on and all Pumas So basically 1 pipe. WLH500050 110/130 TANKS 1. WHK100050 (XA159807 to 8A760303) (all Td5s and early Puma) [superceded to LR013167] 2. LR013167 (8A760304 onwards) The tank change point doesn't match the filler hose change point so I don't think there's a tank inlet size change like for the 90, but I'm happy to be corrected. ![]() ![]() Last edited by Martin on 20th Oct 2020 5:12pm. Edited 1 time in total |
Brilliant Martin,
Thanks for clarifying! ![]() Steve 02' 110 TD5 Double Cab Rebuild Thread |
