Home > Maintenance & Modifications > Soft A Bar Puma vs TD
Grenadier
I'm looking to buy a Soft A Bar from a forum member. I'm sure it will be confirmed shortly, but his vehicle list implies he drives a Td5 whilst I have a Puma with AC nose. I've looked at some on line photos and the A Bar seems to be the same, so I'm wondering if just the brackets need changing? Does anyone know if this will fit my truck if I get AM brackets from Flatdog etc, or if the actual A Bar is different as well?
Thanks in advance. Keen to get an answer to Bev asap so he can continue the sale if need be. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #862193 18th Oct 2020 7:19am
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
This is a soft abar from a 2004. The brackets are different to the later ones so be careful. I had a local fabrication company make a new set for me as mine were too corroded. I hunted high and low online and you cant buy them any more.
Post #862203 18th Oct 2020 8:17am
Grenadier
Thanks Andy. I could do the same for the brackets, the question I shall more whether the A Bar itself is the same/different between Td5 and Puma AC. I can't see that it is and the brackets may be the answer. Monsieur Le Grenadier
Post #862205 18th Oct 2020 8:32am
If the TD5 also has A/C then the front end is exactly the same. I don't know for sure whether these A bars came in A/C and non-A/C flavours but I doubt it. If not however, it won't even matter if the TD5 doesn't have A/C. Darren
Post #862206 18th Oct 2020 8:57am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I thought the only difference in the A bars was the lack of the lower cross member for the winch variation . Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #862214 18th Oct 2020 9:17am
mk1collector
There are two different kinds of brackets (I think) but they should all fit any front end as the mounting points are all the same. Thumbs Up You might have to drill a couple of hole in the slam panel. I have had a play with a few a bars Rolling with laughter and do have a brand new genuine Unused for sale if anyone is after one Whistle
 Ray
My build thread
Post #862215 18th Oct 2020 9:23am
rustandoil
Ive just removed my soft A bar from my TD5 air con....cant see why it wouldn't fit the Puma, the brackets are rubbish, if were to refit mine I would drill through the bumper and fix with a nut and bolt...
Post #862236 18th Oct 2020 11:26am
Force64
United Kingdom 2005 Defender 90 Td5 SW Tonga Green
I have a non winch A bar taken off my 2005 td5 as it now has a winch on.
If interested pm me and I can send some photos.
Andy Defender Td5 XS90
Post #862238 18th Oct 2020 11:27am
mk1collector
If it’s a genuine winch bumper it’s only two cuts to your a bar and it will fit. The cuts are all marked up on the a bar already too Thumbs Up Ray
My build thread
Post #862241 18th Oct 2020 11:52am
Grenadier
Thanking you all, I think I have my answer. Thumbs Up Monsieur Le Grenadier
Post #862261 18th Oct 2020 3:21pm
