Home > Puma (Tdci) > Puma engine oil sump pan |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17416 |
1) Yes.
2) With one of these, or something similar: https://www.lasertools.co.uk/product/5026 3) Probably, but bearing in mind that the genuine ones are not great perhaps not as bad an idea as at fist it might appear. 4) The very early 2.4s had a sump which would get walloped and ruptured by the front propshaft on full axle deflection. I can't remember when the sump changed, but I think it was about 2009 and I would be astounded if the aftermarket ones were the original defective design. Make sure you get a Landrover sump not a Transit sump, of course. |
17th Oct 2020 4:56pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20413 |
I chose a genuine one for mine, I didn’t do it myself but it’s been fine since and the last one lasted ten years.
It began to leak from the seal on mine. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
17th Oct 2020 5:21pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4212 |
Cheers chaps, most helpful. Not seen one of those little gadgets for separating the gasket before 2007 110 TDCi Station Wagon XS
17th Oct 2020 6:46pm |
Is there anything else I need for this job, apart from liquid gasket? I assume the bolts can be re-used. 2007 110 TDCi Station Wagon XS
18th Oct 2020 9:08am |
I had the fixings replaced, but I don’t doubt you can re-use them. $W33T $0U7H3RN $UG4R
18th Oct 2020 10:58am |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 237 |
My 2.2 puma pan rusted through so I bought a Bearmach one was identical in every way to the original. Used wrecking par to leaver old one off - liquid gasket.
Don't waste your money on an original part for this |
18th Oct 2020 5:36pm |
Thanks, that’s good to know. 2007 110 TDCi Station Wagon XS
18th Oct 2020 5:47pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 381 |
I had to change my sump pan that had rusted. (2015 Puma!). Anyway, it was a pig of a job. I didnt have the special tool and couldnt easily find a pry space that was not going to damage the engine block.
In the end I put holes in the sump and pulled the pan with webbing while gently trying to prise in one corner that didnt damage the block. it took me two hours! I used a genuine LR pan. about £120.00 including the special sealant. Good luck! 2015 90 XS Santorini Black |
19th Oct 2020 9:48am |
Thanks Vitesse, I'm definitely going to get the separator, it's only cheap, to make the job easier. 2007 110 TDCi Station Wagon XS
19th Oct 2020 11:37am |
I just stuffed pry bar into the back lip of the pan and used the ARB (if I remeber right) as a lever point and gave the bar a good hard pull
4year old sump pan with very nearly a hole - very bad damp spot. one I had the old pan on the flor pushed the damp spot with a screw driver (lightly) and it went through |
19th Oct 2020 5:22pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8043 |
Late 09 the sump pan design changed. 8 had a 59 plate that arrived with the original style pan that I had changed by lr. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
19th Oct 2020 6:48pm |
Just a bit of an update on this. Bearmach seemingly offer both the original design and the notched sump so you need to be careful still. The original being £10 cheaper. The notched sump has A suffix on the part number 2007 110 TDCi Station Wagon XS
30th Oct 2020 2:09pm |
I’m going to swap today. Any opinion on how long I need to leave it before I refill with oil afterwards? 2007 110 TDCi Station Wagon XS
22nd Nov 2020 12:04pm |
