Home > In Car Electronics > 2.2 Puma no start
Low Boxer
United States 1990 Defender 90 200 Tdi SW Nato Green
2.2 Puma no start
I have some guests from Chile with a 2015 2.2 Puma with a faulty ignition switch that was getting more difficult to turn with the key. It finally quit in my yard. The key turned fine but nothing happened. so I assumed the switch broke internally. After replacing with a new Genuine ignition assembly the key again turns fine but the vehicle will still not start. When turning to the start position no dash lights illuminate and nothing happens in start position. The two small red alarm lights sometime illuminate solid and sometimes do not illuminate at all and do not flash. It has an immobilizer with no alarm, no remote locking. Just a simple fob that needs to be in proximity to the ignition. I have 13 volts at the battery, side lamps and safety flashers function but nothing related to the ignition does. I replaced the battery in the fob, checked fuses under the column and in the seat box, still nothing. I am thinking it might be the mobilizer has failed and maybe this fault is not related to replacing the ignition switch?. I am not familiar with Puma immobilizer systems and appreciate any advice as to what else to try. Thanks.
Post #860921 11th Oct 2020 12:03am
Dinnu
Check that there is 12V at the ignition switch supply. If there is no 12V most likely FL1 (60A fuse) is blown. I think its location is under the right seat. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #860922 11th Oct 2020 4:55am
Ianh
When replacing the ignition switch did you disconnect the main battery ? If you did , did you follow the procedure to turn ignition switch to position 2 then back and remove key , then disconnect battery negative terminal within 15 seconds ? This stops the alarm going off if you have one, but may also impact the immobiliser .
Also have you tried synchronising the fob. From outside vehicle with doors closed pressing the fob locking button 4 to eight times quickly. This will make the indicators flash once to confirm resynchronisation,, wait a second then press the unlock button once. Get back in vehicle and try starting with Fob in close proximity to key
When you change the fob battery the procedure to follow is to sit in vehicle With doors closed. Have fob close to key in ignition. Turn key to ignition 2 position then back and remove key. You now have 5 mins to replace battery if you don’t open door. So remove battery. Hold down one of the buttons to drain remaining power in fob. Replace battery. Close fob. Open door. From outside truck resynchronise fob by pressing lock button at least 4 times quickly and the indicators will flash. Then press unlock button and all should be ok to start truck with key and fob on same key ring. If you did not follow this procedure you could have lost sync between fob and alarm module.
If that does not work it may be that the fob needs to be reregistered with the 10as alarm unit. This can be done with a nanocom or equivalent. If they have there emergency key access (EKA) code that would help as well.
In essence if you don’t have blown fuses and the wiring is ok it may be that the 10as alarm module has lost sync with the fob and the engine is immobilised until the fob is resynchronised or re registered.
After all that I’m wondering if they have the newer fob with integrated key, or a different fob as they don’t have alarm or central locking. The above is about the two button fob that is separate from the key plus the 10as alarm unit.
Post #860950 11th Oct 2020 11:11am
Low Boxer
Really appreciate your replies. I ruled out a blown fuse. I did not disconnect the battery when I changed the ignition switch and I did not change the fob battery inside the vehicle. As soon as it warms up I'm going back out to follow your sync procedure.
I noticed yesterday when I was pressing the unlock button the flashers would come on. Thanks for the boost I'll report back as soon as I've solved it.
Post #860957 11th Oct 2020 12:06pm
Low Boxer
Quick up date while I thaw out my hands. I followed your instructions, synced the fob to the ignition which all seems to be functioning now. If I press lock on the fob the horn will go off when I leave one of the doors open so I think it is working. The ignition is still dead, no dash lights and there is no power at the 60 amp fuse in the seat box (has a Key symbol) I assume that fuse block must be fed from the starter solenoid? Or does the immobilizer feed that fuse? I can't even see the starter. Fortunately despite the strong north wind its bright and sunny out so I should be able to test the solenoid once I warm up again. Sure wish I had a wiring diagram. Owners manual is helpless, its all in Spanish. At least its a nice clean truck to work on.
Post #860978 11th Oct 2020 2:30pm
Low Boxer
Its a two button fob with no key attached.
Post #860981 11th Oct 2020 2:33pm
Martin
Site Admin
If you have no dash lights when you turn the key then you have a fuse or wiring issue - not an immobiliser problem.
The factory fit immobiliser will not and does not cut the whole ignition. So you either have no Battery supply to or Output from the ignition switch.
Check you have connected the ignition switch correctly, I will find and post the correct layout shortly.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #860988 11th Oct 2020 2:57pm
Martin
Site Admin
Double check this!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #860990 11th Oct 2020 2:59pm
Martin
Site Admin
Check for power on BOTH sides of the FL1 60A fuse.
This is a fuse in a permanent battery feed to the ignition switch so it should be “hot” on both sides at all times.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #860996 11th Oct 2020 3:51pm
Ianh
Martin is correct as ever Smile
And if for future ref you need a full workshop manual in English.. then follow this link posted by dgardel on here. https://1drv.ms/f/s!AnHBx4Wc2MJLtxvK7zpu3OJd4yZI
This has wiring diagrams as well.
Post #861003 11th Oct 2020 5:10pm
Low Boxer
Thank you Martin, You called it. I took the dash back apart and there staring at me was the disconnected white wire. I must have knocked it off wiggling the ignition switch back into place. Over 40 years working on Land Rovers and I still make the dumbest mistakes. Really appreciate the support you guys are amazing. Thanks again.
Post #861036 11th Oct 2020 7:30pm
