![]() | Home > Puma (Tdci) > P0101-17 Fault right after remapping |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
Mine had the same fault but only after a few days of whooshing sounds. Turned out to be a split intercooler hose.
Did you change the hoses at least when you did the Remap? Chances are the hoses were on the verge of going and the remap just tipped them over the edge. If you have a remap I'd suggest you change the hoses anyway as sooner or later they will split. |
jbullis Member Since: 28 Apr 2013 Location: Jonesborough, TN Posts: 24 ![]() ![]() |
I didn't change my hoses. The truck on has 20K miles on it. The short hose that cause the most problems look ok. I may have to take the hoses out to inspect. I was hoping not to have to do that.
Mine was the top hose. Luckily the easiest one to check. 😏
Just out of interest did you go for the 150 or 170 map? |
170 hp
The truck already had the BAS intercooler on it...
trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 405 ![]() ![]() |
Perhaps it would be an idea to contact Pete Bell himself, he is very helpful and may be able to help you out.
I have been working with Pete, I posted this post before he responded to me. He has been fantastic, helping me problem shoot. The bad thing is that I just can't drive to his shop, I'm across the pond... lol
Yep, I can see that being an issue🤔
