Home > Puma (Tdci) > P0101-17 Fault right after remapping |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 874 |
Mine had the same fault but only after a few days of whooshing sounds. Turned out to be a split intercooler hose.
Did you change the hoses at least when you did the Remap? Chances are the hoses were on the verge of going and the remap just tipped them over the edge. If you have a remap I'd suggest you change the hoses anyway as sooner or later they will split. |
10th Oct 2020 5:43pm |
jbullis Member Since: 28 Apr 2013 Location: Jonesborough, TN Posts: 24 |
I didn't change my hoses. The truck on has 20K miles on it. The short hose that cause the most problems look ok. I may have to take the hoses out to inspect. I was hoping not to have to do that.
10th Oct 2020 5:48pm |
Mine was the top hose. Luckily the easiest one to check. 😏
Just out of interest did you go for the 150 or 170 map? |
10th Oct 2020 6:08pm |
170 hp
10th Oct 2020 6:28pm |
then even if the fault isn't the hoses this time I'd suggest you buy the silicone ones asap. And probably an intercooler.
10th Oct 2020 6:33pm |
The truck already had the BAS intercooler on it...
10th Oct 2020 6:39pm |
trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 405 |
Perhaps it would be an idea to contact Pete Bell himself, he is very helpful and may be able to help you out.
11th Oct 2020 2:10pm |
I have been working with Pete, I posted this post before he responded to me. He has been fantastic, helping me problem shoot. The bad thing is that I just can't drive to his shop, I'm across the pond... lol
11th Oct 2020 2:35pm |
Yep, I can see that being an issue🤔
11th Oct 2020 5:37pm |
